Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Tran x lsd
Old Oct 9, 2011 | 07:57 PM
rizla's Avatar
rizla
Default Tran x lsd
I would like to back my tran x lsd off need to know what order to put the plates to back it off its on my mk2 Escort any pics of one stripped down would be great Thanks
Old Oct 12, 2011 | 12:30 PM
XRT_si's Avatar
XRT_si
What are you trying to adjust exactly? As it's more likely you will want the ramp angles changed rather than the pre-load/plates?
If it is the plates, just pack them so less of the friction plates are touching each other; it will be quite simple when you pull it apart. There's a rough guide that will give you a better idea printed in September 2011 Classic Ford magazine
Old Oct 12, 2011 | 08:26 PM
rizla's Avatar
rizla
Yeah i did read that in classic ford and i think your right about the ramp angles .
I get this noise when i turn into a junction at a slow speed nothing when im going straight only when i turn into junctions or roundabouts .I was running a 4,1 cwp but sent it away to Burtons and had 3,54 fitted and they set it all up and then i fitted it all back on the car the i notice the noise as if its trying to lock up .
TPM961
Jan 15, 2018 10:50 AM
mk1turboestate
Dec 2, 2015 08:31 PM
155lee
Oct 24, 2015 11:11 AM
dalmarshall
Oct 1, 2015 06:46 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
