Another project of mine RS2000 Cossie mk1
Been doing this car for a while now. Comes back from painting tomorrow. Its RS2000 with steel bubble arches, 4 linked, turreted, 500bhp rated rear axle, gaz coil overs, discs all round, wilwood calipers, full roll cage etc. Just got some 15 x 8" genuine minilites with 225,50,15 tyres. Engine is running T34, greens, 3 bar map etc. has been recorded at 358 bhp.
Here's some pics, will post more when it comes back from painting and i've put the wheels on.
thanks
John
thanks
John
back from painting and wheels on.
Got it back today, proper paint job, fitted the wheels. Looks great. Put the roll cage in (sort of). Fitting engine etc. next week.
John
John
Does look just like yours. Cant wait til Monday as i'm fitting the engine and box in. All work is done, just putting back together and building back up to do.
Will post more pics Monday when more progress is made.
engine now in.
Hi guys
Engine is now in, sorted where all wires go. Fitting gearbox and prop tomorrow. Should be running by the end of the week.
here's some more pics.
I have been working on the car all evening. If you look at the pics of the engine, it sits slightly to the right and not in the middle. I have turned the engine mounts round the other way so the right one is the left one etc. but this throws it out completely. I am baffled as to why the engine sits to the right as other mk1's i've seen that are running cossie engines sit in the middle. I have a world cup crossmember and wondered if my mounts might be wrong. Can anyone help?
thanks
John
thanks
John
mk1 cozy
hi john i,m also running a wccm but with uprated urethane centre,s and home made steel engine mounts, not by me tho as they came with the wccm when i bought it. i,ll ask glynn tomorrow as he,s fitted my engine to see if he can help ya out mate! also mate, where are ya based?? as i,d like to compare when we,ve both finished! i live in luton bed,s
Never mind, i made some new engine mounts this morning. Engine is now in properly aqnd sitting where it should. Gearbox ios in, windscreen is back in. Pedal box is in but not connected. Coming along nicely now. Wont be long!!!!
My mate is also doing one and had the same problem with engine out of alignment, turned out to be Crossflow mounts, you may have the same ones?? just a thought.
Looks like a fun project. Old school rocks right? See you at the streets once it is finish. Goodluck man..
_________________
Must see: Autopartswarehouse.com
_________________
JK12
33
26-04-2021 12:09 PM
