Attn!!! **All peeps running cossie 4pots on mk3&4 Escort
Old Jul 21, 2004 | 05:50 PM
BillyCabrio's Avatar
BillyCabrio
Default Attn!!! **All peeps running cossie 4pots on mk3&4 Escort
Attn: Mr Rainbird, Adam other peeps that have a cossie brake set-up.
Ok guys, those of you that know what i am upto will know that i "WAS" in the process of fitting Sierra Cosworth 4pot callipers to my mk3 Escort Cabriolet. I drilled out the mounting holes on the hub and bolted them up with M12 bolts.
And fitted like this
I had the callipers temporally mounted in place and thought before it all went spirilling out of control i'd fit one of my rims i'm going to be using - a S1 15" 7 spoke Rs wheel.
I bolted it up and yep just as i thought it fouls the calliper quite badly, if the disc were on to it clear that no problemo its just that its fouling the rear of the wheel
So was i wrong to even start this fitting of cossie brakes, i've seen so many conflicting stories on here and crossed advice It seems the depth of the wheel isn't big enough to clear the calliper, which is a real shame - cos i fooking like these!
Is there anything i can do to remedy this or is it a fact of it they just aint going to fit? I was under the immpression that the cossie came with these behind 15" rims as standard??? But i have a feeling the cossie sat on deeper rims than what i have and thats how it cleared the callipers.
Looks like i'm going to have a set of callipers on ebay soon..............
Advice please lads and lasses,
Old Jul 21, 2004 | 06:28 PM
BillyCabrio
Old Jul 21, 2004 | 06:59 PM
AndyRST's Avatar
AndyRST
Paul can you not get material machined off the calipers so the rims fit on over the brakes?
Old Jul 21, 2004 | 07:08 PM
johncossie's Avatar
johncossie
yer dont you have to get the calipers machined
Old Jul 21, 2004 | 07:20 PM
BillyCabrio
Nah if i were to get that done the callipers would foul the rear of the wheel even more!!
Its as if the calliper needs to be mounted further awy from the wheel.
I think i may just scrap the idea and get The Billet 4 Kit which consists of:
One Pair of Discs, Cross-drilled or Grooved
One Pair of Aluminium Mounting Bells
One Pair of HiSpec Billet 4
One Pair of Mounting Brackets
Hardware Pack
285/24mm Billet 4 Ł480.00+vat
Old Jul 21, 2004 | 08:01 PM
BillyCabrio
Old Jul 21, 2004 | 08:48 PM
James Raby's Avatar
James Raby
Had said kit on my old Red S2, needed wheel spacers matey
No other alternative
Cossie 2wd have an offset of ET40 too, which makes a difference...plus the spokes aren't as wide
Your standard ones above are ET35 I think
Old Jul 21, 2004 | 09:14 PM
weegaz22's Avatar
weegaz22
how do you mean its hitting the rear of the wheel? the spokes? cossies came with a different offset so wheel spacers may be needed, have you tried it with the disc on? have you got the right amount of spacing on the caliper bolts? are u sure the caliper isnt fouling on the wheel balance weights?
dont you have the calipers the wrong way round? from what i heard the bleed nipples are usually round the bottom when you do the cossie conversion as ive heard people saying its a pain in the arse to bleed
Old Jul 21, 2004 | 09:24 PM
BillyCabrio
James - Have you any idea what sized spacers you used?
weegaz22 - Yeah its fouling the rear of the spokes, as james said about the offset and as i suspected it maybe an offset thing. Not tried it with the discs on yet, cos i aint got'em Spacing on the calliper bolts?? Its defo not fouling the balencing weights and as for having the callipers upside down, i could well do mate - I'm still not 100% sure this is worth all thsi hassle
Old Jul 21, 2004 | 09:40 PM
Benn 304R's Avatar
Benn 304R
paul, we will have them at a special price
Old Jul 21, 2004 | 09:41 PM
BillyCabrio
Benn, :eatmyhole:
Old Jul 21, 2004 | 09:42 PM
Benn 304R's Avatar
Benn 304R
is that what ya want for payment, fine by me
Old Jul 21, 2004 | 09:46 PM
James Raby's Avatar
James Raby
think it were 5mm, but all they had at the time mate - was on S2 rims
This was with replacement bells too as previous ones were way too small
Old Jul 21, 2004 | 09:48 PM
weegaz22's Avatar
weegaz22
once the discs are on it should probably give you the clearance needed, the spacing was the amount of washers used to get the caliper correctly centred with the discs, think its 10mm or something, have a look at other threads as i may be getting confused with something else
Old Jul 21, 2004 | 10:00 PM
James Raby's Avatar
James Raby
the discs need BELLS mate, not silly washers for the bolts
Old Jul 22, 2004 | 06:16 AM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
I could of told you that them wheels aren't gonna clear the calipers
Wheel spacers or machining on the caliper is the only other thing to to
Or just get a set of 16"/17" wheels
Old Jul 22, 2004 | 06:22 AM
James Raby's Avatar
James Raby
Adam, if asked anyone could of told him
But you never realise these thigns until you actually so the job, I'm stubbern and learn this way LOL
go for 16's, much better choice and perfect for handling
Old Jul 22, 2004 | 07:00 AM
Blakeya's Avatar
Blakeya
Billy,
I fitted 4x4 front discs & 2wd 4 pots to my series one when i had it with no problams at all. I was also running on standard S1 wheels. The only thing i did use was a 2.5mm washer between the caliper & mounting point to centre the disc in the caliper. BTW, Your picture shows the caliper mounted on the wrong side of the mounting bracket. You need to move it to the outboard side (ie between the hub & strut, not on the back as you have it) Don't give up mate. You have bought the bits required! Where there is the will there is always a way.
HTH
Andy
Old Jul 22, 2004 | 04:02 PM
BillyCabrio
Cheers for your replies chaps.
Adam seems to be the one thing i forgot to mention when asking before was the fact that i was on standard rims
James - I was working on the fact that the coz came wiv 15" rims, just never took the fact that the cos came with 205's on and not 195's Oh well we live and learn And as for 16's, no way!! 15's for me, wanna keep it sheep in wolf overcoat if ya see what i mean
Blakeya - I 'was' getting the correct bells and rotors off of Mr Rainbird so i had no need for washers and i tried mounting the wheel with the calliper where it is and there was still no clearence to fully bolt the rim up, if i put the calliper onto where you say i should would there not be even less clearence?
Old Jul 22, 2004 | 05:11 PM
James Raby's Avatar
James Raby
You'll get it to fit, you'll just need bigger bells
Old Jul 22, 2004 | 05:56 PM
Shings's Avatar
Shings
cossie came with 7 inch wide rim and a different offset.
The 2wd 4 pot is a big caliper and doesn't fit behind the wheels. I found this out.
just get some 16's they're cheap enough
Old Jul 22, 2004 | 06:15 PM
Damo V's Avatar
Damo V
Paul, as per Blakey, the calipers are mounted on the wrong side of the hub brackets but the bleed nipples are right way up.
Again as above, the discs will bring the wheel out too, just get the bells made a bit thicker, and then check your bolts are long enough.... If yours are et35 and a saff is et 40, thats 5mm extra clearence required... at least I would imagine
Damo V's Avatar
Damo V
Oh and that hi-spec shit, that aint gonna go behind 15 either is it??
Old Jul 22, 2004 | 06:25 PM
BillyCabrio
http://www.hispecmotorsport.co.uk/Road%20Kits/ford.htm
285/24mm Billet 4 Ł480.00 tis the biggest to go behind 15" rims.
So what you saying is, if the bells are 5mm thick i might be ok?
Old Jul 22, 2004 | 06:31 PM
Damo V's Avatar
Damo V
Nah if the bells are an extra 5mm over std .. you "may" be ok, ie instead of using 5 mm spacers ay
Old Jul 22, 2004 | 07:49 PM
Lee @ Fusion's Avatar
Lee @ Fusion
Havnt read all the posts mate but this is what u need to do , Have 5 mm removed from the caliper where it mounts to the hub .
his will allow the disk to fit ,
Then to use a S! rim u need 15 mm spacers . have had this issue with the track car , in the end i have used saph latice wheels , these are 15's but were designed with caliper clearence in mind .
Old Jul 23, 2004 | 07:16 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
As Lee has kindly pointed out, just because they are 15" rims, doesn't mean they are going to fit . Each wheel has different rim widths and / or offsets, as well as different clearances inside the wheel, so just because it is a 15" wheel, doesn't mean squat .
If it was MY S1, I would want to keep the original wheels, so my advice would be to do what Blakeya did - just use 4x4 discs....
Old Jul 23, 2004 | 07:55 AM
XS's Avatar
XS
Hello dude. We can have a good look at this on Sunday. Have you got the brake discs yet? As has been said, they will push your wheels further out. Don't panic, you have just been a bit premature with the trial fitting (Not the first time you have been associated with that word ) Until the disc are on you are not going to know what needs doing.
Never fear, I will bring my dremel and soldering iron We can get this to work!
Old Jul 23, 2004 | 08:36 AM
BillyCabrio
Is that Coz 4x4 or Xr 4x4 discs that you speak of oh knowledgable one?
I'll give you premature ya cheek geeet!
I think i'm getting a little inpatient now, just wanna get it done
Old Jul 25, 2004 | 07:08 PM
Lee @ Fusion
Billy ,
Another option for you is a 2WD disc , mounting bracket ( conversion bracket High spec etc stock em) and use the standard caliper , ( or a slightly better S2 caliper )
This conversion will give u a nice big disc but will allow the fitment od standard wheels .
Vincereese
Jun 1, 2023 09:14 AM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
Vincereese
Aug 18, 2015 03:57 PM
y4n
Aug 17, 2015 12:12 PM
Vincereese
Aug 16, 2015 06:38 PM
