not starting
hello people
i have a xr2 which i fitted a escort rs turbo engine on completeion the car wouldnt start theres a spark but the injectors arnt injecting till i turn the ignition off none injected whalst cranking can someone please help me it will start but only for about 5 seconds at the most most of the time its just fireing i think this may be beacuse after i switch the ignition switch off it injects fuel into the cylinders so on initial crank its got fuel so starts then dies after alot of cranking with both the cold start valve connected and disconected i inspected the plugs and they were black ???
can anyone help chears
luke
luke
SPARK PLUGS ARE BLACK = OVER FUELLING!
ARE U SURE UVE GOT THE SNSOR PLUGS ON THE BACK OF INLET MANIFOLD CORRECT?
BLUE PLUG COLD START
BLACK PLUG AUX AIR DEVICE
YELLOW: THERMO TIME SWITCH
BEIGE :TEMP SENSOR
BEIGE :TEMP SENSOR
This is my mate just for info.
The pump is priming, there is shitloads of fuel pressure there, but when cranking even with the flap fully depressed there is no fuel spraying from the injectors, the only times we have seen fuel come out the injectors is for a split second when you stop cranking? Its well wierd never seen anything like it?
It should be wired right as i helped him with the wiring, but to be honest KE Jetronic even in the event of a fault will operate in a limited economy and performance mode (as a K Jetronic system), its the fueling issue.
Has anyone ever seen a fault like this?
new information fuel only sprays from the injectors if when the ignition switch is turned off the fuel pump is still running if the ignition switch is turned off after the fuel pump has stoped running it wont spray when the ignition switch is turned off. i bridged the perminant live terminal on the fuel pump relay to the fuel pump live and the injector continuasly sprays, whats strange is that when cranking the fuel pump can be heard running but doesnt inject without the bridge in place have tryed cranking with bridge in place but doesnt start just fires occasionally
does anyone know whats going on
Originally Posted by xr2turbo77
u reakon a wireing fault then andy
a known working silver ecu
a known working black ecu
a known working pink relay
& a known work brown relay
that would be my starting point, if nothing else that totally rules out all those components therefore you can concentrate on the wiring.
Originally Posted by safechav
Wiring fault im tellin u luke, i told u them wires on that plug for the hydro electric pressure actuator were the wrong colours
At least you've found the fault though
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
