R THERE ANY ERST PEEPS IN SWINDON??
Old Jan 31, 2006 | 12:50 PM
COSSIE 1's Avatar
COSSIE 1
Default R THERE ANY ERST PEEPS IN SWINDON??
r there any erst peeps living/or know anybody in swindon that i could meet up with and have them listen to my engine and ill take them for a spin 2 see if ive got a problem, ive got a whinning sound that im not sure if ive got a problem or is normal ...cheers
Old Jan 31, 2006 | 12:55 PM
dave_y's Avatar
dave_y
probably gearbox, i have noticed this recently too on my RS
Old Jan 31, 2006 | 01:10 PM
twinkle_2k86's Avatar
twinkle_2k86
im in andover mate, not to far from swindon, i will have a listen if you can find anyone else local
Old Jan 31, 2006 | 01:13 PM
COSSIE 1's Avatar
COSSIE 1
dont think its the gearbox more cambelt overtightened??, airleak that gets worse on boost.........but might be normal
Old Jan 31, 2006 | 04:25 PM
rs_daz's Avatar
rs_daz
Put the clutch down does the sound go?
could be cam belt is too tight has it been off recently/changed? you should be able to twist it slightly.
If it happens when it comes on boost could be air escaping from one of the boost pipes making the noise(check clamps) or the turbos on the way out.(check for play in the turbo.No in and out movment 1mm up and down movement is OK)
Old Jan 31, 2006 | 07:00 PM
COSSIE 1's Avatar
COSSIE 1
it whistles when u rev it, its difficult to hear it when the cars stationary and ur over the engine bay, but when u drive it u can hear it, it gets louder the higher u rev it..........
Old Jan 31, 2006 | 07:10 PM
rs_daz's Avatar
rs_daz
Cam belt
Old Jan 31, 2006 | 07:20 PM
COSSIE 1's Avatar
COSSIE 1
rs daz where abouts in cheltenham are u... u sound like a perfect person to see mine..........how r u sure its the cambelt??....
Old Feb 1, 2006 | 12:28 AM
rs_daz's Avatar
rs_daz
Quessing like everyone else does on here lol does sound like it tho as u say when u rev it its louder etc..
Old Feb 1, 2006 | 12:39 AM
antony215's Avatar
antony215
Escort Rs Turbo
As above could be the cam belt to tight or it could be the bearing's in the altanator on there way out
cossie362
Oct 11, 2015 03:53 PM
Mc5506
Oct 5, 2015 09:57 PM
paceo
Sep 25, 2015 08:05 PM
beller
Sep 21, 2015 04:13 AM
paceo
Sep 17, 2015 12:12 PM
