Trust electrical inlet
Old Jul 21, 2004 | 10:02 AM
Sunil_FiestaRS1800's Avatar
Sunil_FiestaRS1800
Default Trust electrical inlet
i got this on monday and its a bit harder to fit than i thought. I thought it would be a straight swap for the orginal but it needs some thinking to get it working.
This is what the kit contains. The inlet mainfold with space for injectors and rail. A blanking plate, a circular plate with inlet, a rectangler plate that bolts onto std butterfly bit of throttle body, and lastly a pipe to connect the inlet to the butterfly/linkage etc
inside inlet
inlet ports
back of inlet
the different plates
layed out how it fits together
the iscv i need to bodge into all this somewhere for cold starting
throttle linkage etc.. that will bolt onto rectangler plate and need fixing somewhere. but where??
The problem i have is i need this fitted by monday as i have a live mapped booked at MSD. I need to figure out where im gonna mount all the throttle linkage etc.. and where and how im gonna fit the iscv into all of this. any ideas welcome
also does it look like this will give me any gains in performance??
Old Jul 21, 2004 | 10:08 AM
Ryan's Avatar
Ryan
quite supprised the inlet doesnt have inlet track trumpets
Old Jul 21, 2004 | 10:13 AM
Sunil_FiestaRS1800
what are they then??
Old Jul 21, 2004 | 10:18 AM
Sunil_FiestaRS1800
Oh and heres another question. When i take iscv will it have two connction for me to slip to slip a couple of pipes over then screw one pipe into the inlet where the temp sensor is at the top and one into the pipe im gonna use from the maff sensor to the linkage.
Old Jul 21, 2004 | 10:34 AM
B19-TRB's Avatar
B19-TRB
your engine NA!? or turbo!?
Old Jul 21, 2004 | 10:37 AM
Sunil_FiestaRS1800
2.0 na with a healthy spec
Old Jul 21, 2004 | 10:39 AM
B19-TRB's Avatar
B19-TRB
do thy do these inlets for turbo!? does it make adiffeence!? :s
how much was it!?
Old Jul 21, 2004 | 10:43 AM
Sunil_FiestaRS1800
got it from www.trustelectrical.co.uk . It is meant to come with an omex management system, but i thought it would be better and cheaper for me to just get the inlet and let MSD do the map on my std management.
Old Jul 21, 2004 | 12:08 PM
Sunil_FiestaRS1800
BTTT
still need an answer on this:
and on a good place to mount the bit that the throttle linkages goes on.
Old Jul 21, 2004 | 12:44 PM
CabrioTurbo's Avatar
CabrioTurbo
i would of personally thought it would be ok without using the cold sart injector... they are only there for when its REALLY cold (well they are on an ERST anyway )
Old Jul 21, 2004 | 12:55 PM
Scott R's Avatar
Scott R
If you get a remote housing from an early xr2i, you can then mount it the ISCV anywhere, just need to get a pipe either side of the throttle body to it as per normal IIRC
as for your throttle housing etc, i would think that you will need to re route it, so that it sits on one end of the inlet, and mod everytjing else occordingly.
Old Jul 21, 2004 | 01:18 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
did you not get any fitting instructions mate??
personally, what i would do is mount the round bit with the hole for the inlet so its facing IN to the plenum with the t/b bolted directly to it, it looks as tho you have enough metal to drill the 4 holes and bolt the t/b on to it.
be easyer to route the throttle cable too.
Old Jul 21, 2004 | 01:22 PM
Sunil_FiestaRS1800
not quite sure what u mean. do u mean put the circualr inlet plate for trust t/b on the wrong way then bolt the other bit which goes on to the linkage and that straight onto it??
Old Jul 21, 2004 | 01:32 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
yes and no....
i mean mount the round plate so it is facing into the inlet, dont use the square bit at all, except to mark the holes for the t/b to be mounted to the round bit.
if ya get me??
Old Jul 21, 2004 | 01:34 PM
Sunil_FiestaRS1800
if you did mean that it work cause the circular inlet thing wont go round the other way as the welds stop it from going butt up.
i cant see where im gonna fit all this and it dont look like i will be able to doit by tuesday so i might just send it bak.
Old Jul 21, 2004 | 01:46 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
like this
Old Jul 21, 2004 | 01:49 PM
Sunil_FiestaRS1800
nice pic fudgeass
but no it wont work cause the welds on the outside of circular wont allow it to fit butt up if turned the other way
Old Jul 21, 2004 | 01:50 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
how much did you pay for it mate???
also, if the welds are in the way, get the grinder out
Old Jul 21, 2004 | 01:51 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
nice pic fudgeass
lol v.quick paint shop job...
Old Jul 21, 2004 | 01:52 PM
Sunil_FiestaRS1800
i paid around 170-180 for it (cant remember exactly have invoice at home) , thats including vat and a temp sensor they said i needed.
i dont have the time to fuck about with it to much, plus it will probably fall apart if i go at with a grinder. think im gonna get rid of it
Old Jul 21, 2004 | 01:59 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ill ask my mate if he is interested mate.
although, the alloy inlet you have now, i know of a fez running a 2.1 zetec turbo - with 380bhp!!!
so its not exactly bad at flowing!
Old Jul 21, 2004 | 02:03 PM
Sunil_FiestaRS1800
got any links or pics that might help me see how he has fitted it
Old Jul 21, 2004 | 02:13 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i meant the EFI one on your car at the mo.
i think he uses ford sport, his name is NOZZIE or summut like that.
i spoke to him at FITP, white XR2i
Old Jul 21, 2004 | 02:18 PM
Sunil_FiestaRS1800
oh right, i might just stick with the std inlet then
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
