fuel computer
Old Jan 27, 2006 | 10:48 PM
16vzetec's Avatar
16vzetec
Default fuel computer
i have a 90 spec 3i
i have a fuel computer to go in it.
does it need a bit of loom to connect it to the car or is there a plug in the original loom?
Old Jan 28, 2006 | 12:35 AM
sufsRS's Avatar
sufsRS
not just plug and play m8 quite a few sensors needed
Old Jan 28, 2006 | 08:15 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
If it is a proper 90 spec then the loom will be there. Easiest way to check would be too look under the carpet under the rear seats. You should see a small loom coming out of the middle of the car heading towards the front.
As said you will need sensors. Fuel Flow and Gearbox speed.
Old Jan 28, 2006 | 08:30 AM
16vzetec's Avatar
16vzetec
so i will need a loom from the middle to the computer.
what else?
where does the fuel flow sensor go?
also where is the gearbox sensor, doesnt it just use the speed sensor?
Old Jan 28, 2006 | 08:37 AM
Tony Turbo's Avatar
Tony Turbo
No, if you look under your seat and the loom is there then you have it. It is a complete one piece loom. I don't know about XR3i's but on an RST the fuel flow sensor goes on the metering unit. The Gearbox Spped Sensor goes inbetween the speedo driver and the gearbox. It is round and black and has a plug coming off of it.
Old Jan 28, 2006 | 08:46 AM
16vzetec's Avatar
16vzetec
i dont remember seeing the loom under the seat.
ill have a look later
Old Jan 28, 2006 | 08:53 PM
efiste2's Avatar
efiste2
ok heres how to fit your fuelcom, THE VERY FIRST THING is, if you can find a scrap car that had a fuelcom, and get the multiplug and a couple of feet of the loom connected too it, whilst u hunting one down there should be a yellow plug behind your speedo/dash this is the lights on/power plug to the fuel com. Since ur car is an EFI you can wire the FUEL PULSE and SPEED SENDER wires straight ooff the ECU block using scotchlocks. The fuel tank sender is wired into a black plug that should be under the rear seat cushion. all these wires you need to run to the MULTIPLUG if you have one. ie 3 wires.... one speed sensor...one fuel pulse/usage....one fuel level. see if you can get a plug and bit of loom first then i can tell you wich wires to connect etc etc
Old Jan 28, 2006 | 09:22 PM
dave_y's Avatar
dave_y
i have this loom coming from under my rear seat wondered what it was.
is it difficult to retro fit the fuel computer cause if its an easy job i may stick one in.
Old Jan 28, 2006 | 09:27 PM
efiste2's Avatar
efiste2
EASY if you get a the multiplug and a peice of loom conected to it. otherwise its a little bit messier!. EFI is easeir than MFI as the MFI requires a fuel metering unit attached to the fuel ditributor head in the engine bay!!!
Old Jan 28, 2006 | 10:57 PM
16vzetec's Avatar
16vzetec
looks like i'll be searching for that plug then
timsrs
Nov 13, 2018 11:48 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
