Help, just finnished putting my engine back together
Old Jul 20, 2004 | 06:37 PM
M2YLE's Avatar
M2YLE
Default Help, just finnished putting my engine back together
And the bugger keeps cutting out
It was doing this before I had the engine out but I put it down to a loose boost pipe, but its still doing it now. I’m thinking its a petrol blockage as you can start the car but after a few seconds it cuts out then if I try and start it straight away it wont, you have to leave it a min or two Anybody got any suggestions?
Oh and it’s a RS turbo engine
Old Jul 20, 2004 | 06:43 PM
Hofajoab's Avatar
Hofajoab
i know in the old sierras the carbon canistor/ fuel seperator thing used to play havoc, the car would run for 10 mins then cu-out.. and you had to leave it for a few minutes before it would even start again. Basically it was just bypassed and it ran fine.
might have absolutely nothing to do with your problem but it's just an idea.
Old Jul 20, 2004 | 06:56 PM
M2YLE's Avatar
M2YLE
10 mins would be about 9.30 miniutes longer than mine wants to run if you touch the accelarator pedal it cuts out straight away as well. Think its to do with the thing which the fuel passes through before going into the fuel filter, can anybody tell me what this is/does? Thanks
Old Jul 20, 2004 | 07:00 PM
Hofajoab's Avatar
Hofajoab
the thing i just told you about?
three hoses going on it? fuel in, fuel out, and a vapour one (or whatever it is)
Old Jul 20, 2004 | 07:23 PM
M2YLE's Avatar
M2YLE
Oh is that what that is Thanks, on mine there is only two pipes one in one out. Can i just bypass this? What is it there for? Thanks again
Old Jul 20, 2004 | 07:25 PM
Hofajoab's Avatar
Hofajoab
well the ones i've had in the 1.8 CVH Sierra's have three hoses like i said, but probably the same thing. I just bypassed it and the engine ran fine . A lot of taxi's round about here used to do the same.
I'm not entirely sure what it's for though lol, but it doesn't seem to affect the running of the engine in any way apart from preventing it from cutting out
Old Jul 20, 2004 | 07:29 PM
M2YLE's Avatar
M2YLE
Cool, I’ll give it a try without it in the way and see if the car runs, would really like to find out what it does though before I remove it completely. Thanks for your help mate
Old Jul 20, 2004 | 07:39 PM
Hofajoab's Avatar
Hofajoab
yeah if you find out i'd like to know too, probably something really really simple.
Old Jul 20, 2004 | 10:01 PM
M2YLE's Avatar
M2YLE
Boo, just bypassed the carbon canistor/ fuel seperator thing and it still wont play , really sounds like its running out of something petrol/air, checked all the plugs there getting a spark/ really dont know what to do now Anymore ideas?
Old Jul 20, 2004 | 10:42 PM
Dean Saff's Avatar
Dean Saff
sounds like you maybe better off getting it to a tuner mate. you might find yourself replacing things wasting your own time and money..
Old Jul 21, 2004 | 12:34 PM
M2YLE's Avatar
M2YLE
Please Help Located the problem with the car cutting out
When I start the car with the air filter removed and slightly press the butterfly thingy down the car keep running, I push it a little harder and it idles faster. Does this mean that the car is over fueling badly? and is it normal for the butterfly to sit slighty proud of the lip inside the throttle body? Hope that all makes sence Thanks in advance
So close yet so far !
Old Jul 21, 2004 | 03:57 PM
IANS2RST's Avatar
IANS2RST
air flow meter will need resetting as the it will be set for an old knckered engine not a fully rebuilt 1. if it runs when you press the flap down slightly that means it is underfuelling so you need to richen the mixture by turning the 3mm alen key clockwise.
Old Jul 21, 2004 | 06:54 PM
M2YLE's Avatar
M2YLE
Thanks mate The car is now running all it needs now is a good set up and it should be running sweet, feels so much stronger than it did.
Thanks again
j.hammond1
30
Oct 31, 2021 05:28 PM
ekjim
Aug 17, 2015 08:57 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
