FAO DEANO (OR ANYONE ELSE THAT CAN HELP)
Old Jul 20, 2004 | 06:04 PM
The Sludge's Avatar
The Sludge
garibaldi
Default FAO DEANO (OR ANYONE ELSE THAT CAN HELP)
Okay, got series 2 and when done milage she overheating and water bubbling out of header tank when turned off. Replaced header cap, still no good. Then used hosepipe to run water through pipes by taking pipe off top of thermo unit. Seemed okay for half a day then same thing happened. Replaced thermostat and still the same. Someone told me it might be head gasket and to drive it without going on boost and see if same thing happens-it does!!!
fan aint coming on unless i put me headlights on , pmsl!! any ideas? Deano was gonna post on PJ's forum but u answered todays questions already.
cheers guys
Old Jul 20, 2004 | 08:10 PM
Deano's Avatar
Deano
Definately air getting into the cooling system , would defo checkout the headgasket , have a look on the block for water marks , are you topping up the water often ?
Old Jul 20, 2004 | 08:13 PM
The Sludge's Avatar
The Sludge
garibaldi
no, deano, not topping much at all, mainly cos when i stop it all pisses out of header tank
Dave yesterday told me to drive it without boosting................yet still happening so it cant be gasket now then can it???????????
deano
Old Jul 20, 2004 | 08:25 PM
Thrush's Avatar
Thrush
Irritating c........
Originally Posted by the sludge
no, deano, your a COCK and your advice is shit now FOOK OFF
Bit harsh ain't it m8?
Old Jul 20, 2004 | 08:29 PM
Stoo's Avatar
Stoo
Deano's Avatar
Deano
Well you have air getting in somewhere mate Something is pressurizing your coolant thats for sure
Thrush you are a dirty stinking GREEEEEEEEEEEEEEEEEEEEEEEEEEBO mofo
Old Jul 20, 2004 | 08:33 PM
The Sludge's Avatar
The Sludge
garibaldi
Thrush you are a dirty sticking GREEEEEEEEEEEEEEEEEEEEEEEEEEBO mofo [/quote]
lol=
where air getting in from tho you reckon Deano??? Reckon i shud check all pipes etc????????????????
Old Jul 20, 2004 | 08:40 PM
Deano's Avatar
Deano
Yeah check all the pipes , check your coolant bottle too if its got hot and flexed that may be something to change too , still think you should check for signs of water on the block
Old Jul 20, 2004 | 08:43 PM
Spiky's Avatar
Spiky
cant beleive someone ask a yellow lemon owner advice
Old Jul 20, 2004 | 08:45 PM
Deano's Avatar
Deano
In the same way I cant believe after all the sheep youve sexually abused your still a free man
Old Jul 20, 2004 | 08:48 PM
The Sludge's Avatar
The Sludge
garibaldi
spiky behave lol
deano yeh bottle expanded "a bit" lol
Old Jul 20, 2004 | 08:49 PM
Deano's Avatar
Deano
spiky behave lol
Change it see how you get on
Old Jul 20, 2004 | 08:55 PM
Spiky's Avatar
Spiky
it's a secret, i'll show you one day
Old Jul 20, 2004 | 09:09 PM
The Sludge's Avatar
The Sludge
garibaldi
spiky behave lol
ok matey, if no joy it ok to get in touch with ya please dude?
Old Jul 21, 2004 | 06:25 PM
The Sludge's Avatar
The Sludge
garibaldi
right deano-replaced header tank and cap. filled with water from top rad hose. seemed okay after running for 10 mins. took it for 12 mile run and same thing happened.
No water stains on head
Help!
Old Jul 21, 2004 | 07:10 PM
Deano's Avatar
Deano
There wont be water stains on the head
Look on the block somewhere for a lightish brown stain that will indicate if the headgasket is on its way out
Old Jul 21, 2004 | 07:14 PM
The Sludge's Avatar
The Sludge
garibaldi
ok-when i took thermostat unit off u can see inside head-yeh?? Well that was like browny orangey colour if that helps
Old Jul 21, 2004 | 07:19 PM
Deano's Avatar
Deano
Whats the inside of your oil filler cap like ?
Mate get a torch , a feckin bright one and just look at the block as it sits in the car , you might have to crawl underneath to check the back of it though unless you can see it from side on
Old Jul 21, 2004 | 07:48 PM
The Sludge's Avatar
The Sludge
garibaldi
oil is as clean as fcuk
back of block clean, no water residue or oil leaks etc etc
Old Jul 21, 2004 | 07:55 PM
weegaz22's Avatar
weegaz22
head gasket is leaking from the cylinder into the water jacket, may only be doing it after the engine warms up that the gasket will leak, (rovers are bad for this) it doesnt need to leak on the outside of the block either or contaminate oil
Old Jul 21, 2004 | 07:57 PM
The Sludge's Avatar
The Sludge
garibaldi
cheers gaz
Old Jul 22, 2004 | 09:19 PM
The Sludge's Avatar
The Sludge
garibaldi
sorted today!!! Fan was problem, and me mate bypassed it using seperate relay and fan also comes on when engine turned off for 5 minutes
warleydaddy
49
Nov 10, 2007 03:19 PM
Chris S
Jan 4, 2007 07:11 PM
Disabled Account
14
Oct 25, 2005 06:55 AM
Disabled Account
Jun 14, 2005 06:17 PM
