Shift Lights and Gauge question...
Old Jul 20, 2004 | 10:06 AM
DanS's Avatar
DanS
Default Shift Lights and Gauge question...
I'm thinking about getting a shift light in the near future as my rev counter seems to be out by about 200-300rpm depending on what gear i'm in.
I'm after somthing subtle but does the job as i dont want anything that stands out too much.
Can anyone recommend one on the market to go for?
Also...
i'm going to get the 3 guage pod that goes where the cetner vents are, but what gauges are the most important to have? Oil temp, Air/Fuel ratio Sensor, Oil pressure or a water temp gauge (as the std item is hardly accurate )
Cheers,
Dan
Old Jul 20, 2004 | 10:08 AM
Spiky's Avatar
Spiky
oil temp/oil pressure in one spa, like mine
water temp and volts in another
and the third have egt and boost
6gauges for the space of 3.......
job done
Old Jul 20, 2004 | 10:09 AM
Ragtop's Avatar
Ragtop
Oil temp and pressure are a must... Presume you've already got a boost gauge..??
AFR's are apparently only worth gettin if you spend loads.. Wouldn't bother with water temp, unless it's part of a dual-gauge like SPA's digitals..
Luv
Chrisie...
Old Jul 20, 2004 | 10:14 AM
All4it's Avatar
All4it
job done
so what gauges does all that then Spikyboy
Old Jul 20, 2004 | 10:18 AM
Spiky's Avatar
Spiky
SPA, and i have them
Old Jul 20, 2004 | 10:24 AM
danvisteon's Avatar
danvisteon
i have got the omex sequential shift lights which is nice and neat and compact, they are about £80 i think, my ones are actually set into the dash pod
Old Jul 20, 2004 | 10:31 AM
DanS's Avatar
DanS
thanks dan, i'll look into that one
Spiky: i'm not sure about digital gauges!! Do they do them with blue backlighting?
Old Jul 20, 2004 | 10:33 AM
Spiky's Avatar
Spiky
mine hs yellow and red lighing
blue is defi's and othres, but not spa
IainRS1700T
Sep 25, 2015 06:44 AM
Billy_RS
Sep 13, 2015 04:17 PM
The Enigma
Sep 12, 2015 10:12 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
