Shift Lights and Gauge question...
I'm thinking about getting a shift light in the near future as my rev counter seems to be out by about 200-300rpm depending on what gear i'm in.
I'm after somthing subtle but does the job as i dont want anything that stands out too much.
Can anyone recommend one on the market to go for?
Also...
i'm going to get the 3 guage pod that goes where the cetner vents are, but what gauges are the most important to have? Oil temp, Air/Fuel ratio Sensor, Oil pressure or a water temp gauge (as the std item is hardly accurate )
Cheers,
Dan
Also...
Cheers,
Dan
Oil temp and pressure are a must... Presume you've already got a boost gauge..??
AFR's are apparently only worth gettin if you spend loads.. Wouldn't bother with water temp, unless it's part of a dual-gauge like SPA's digitals..
Luv
Chrisie...
Luv
Chrisie...
Originally Posted by Spiky
oil temp/oil pressure in one spa, like mine
water temp and volts in another
and the third have egt and boost
6gauges for the space of 3.......
job done
job done
i have got the omex sequential shift lights which is nice and neat and compact, they are about £80 i think, my ones are actually set into the dash pod
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
The Enigma
12-09-2015 10:12 PM
