CAR BATTERY
Old Jan 17, 2006 | 05:28 AM
COSSIE 1's Avatar
COSSIE 1
Default CAR BATTERY
Is it possible that i can use a battery that has posts as apossed to the square connectors with holes in?? is it possible to use a clamp and bolt the excisting wires to the battery?
Old Jan 17, 2006 | 07:21 AM
andyt's Avatar
andyt
yeah no problem doin that mate
Old Jan 17, 2006 | 08:24 AM
T28 RST's Avatar
T28 RST
Ok then
Yes coz that is what im doing at the moment
Old Jan 18, 2006 | 02:01 AM
COSSIE 1's Avatar
COSSIE 1
without changing all the connecters from all the wires going on he battery?? i see u can buy adaptors that allow u to clamp/block on to the positive and negative terminals with 2 screws on each one 4 the wires?
Old Jan 18, 2006 | 05:29 AM
SafeChav's Avatar
SafeChav
Its possible, and better IMO. Fuck the standard connectors theyre awful, ESPECIALLY that annoying little fuse-link wire for the main fusebox feed, thats the first thing i cut off and replace with a fuse.
Here's mine:
The only thing i would say, on my positive clamp you can see right on the edge its just catching the bonnet though, a couple of small black arcing marks, theres not a lot of clearance, so try and find some low profile clamps (this is also why i would recommend chopping off the standard connectors, you can always replace them)
That said the size of battery probably doesnt help thats the biggest battery you would ever fit in the tray, can't even get the side clamp on, it covers the holes!
Also note the inline fuse for the fusebox feed
Old Jan 18, 2006 | 05:37 AM
COSSIE 1's Avatar
COSSIE 1
Cool mate ive got a spare new battery from my e36 m3 bosch silverline so ill wack that in, the clamps look the same as those but have screws in instead of the allen bolts which mean i dont have to remove the connectors
Old Jan 18, 2006 | 05:41 AM
SafeChav's Avatar
SafeChav
I'd be very careful when you shut the bonnet down first time.........screwing your connectors on the top will make the top shit quite proud, those connectors ive got aren't overly chunky, and you can blatantly see they have been arcing. Ive got some rubber covers for them i keep forgetting to put them on
The thing i like about those ones, is theres 4 holes, 2 for 8AWG, and 2 for 4AWG, do a good job
PS forgot so appologise for the Renault sticker on the battery
Old Jan 18, 2006 | 05:52 AM
COSSIE 1's Avatar
COSSIE 1
ill do some experimenting and see where i get
Old Jan 18, 2006 | 05:53 AM
SafeChav's Avatar
SafeChav
Remember to have your glamerous assistant shut the bonnet down the first time and stand well back
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
track.focus'd
Aug 12, 2015 05:53 PM
liam-rst
Aug 10, 2015 08:46 AM
tankybaby66
Aug 9, 2015 07:13 AM
xr_craig
Aug 7, 2015 06:00 PM
