The big start up.......
Old Jul 19, 2004 | 07:56 AM
Franco's Avatar
Franco
Default The big start up.......
ok gang I'm looking to start my new engine hopefully in the next few weeks so wanted some advise
The Bottom end is brand new and has not been turned for a few months since it was put in the car, I did pour oil into it just after fitting just in case.
Is there anything I should be weary of when turning her over??
Also what type of oil should I use for the first start up/running in period, any ideas??
Would be grateful for any input at this moment in time as I'm running around getting all the last bits & pieces.
Jason
Old Jul 19, 2004 | 07:59 AM
zvhturbo's Avatar
zvhturbo
Turn the engine for about 1 min with the plugs out mate.
It will get oil round the engine before starting it and putting it under pressure.
Good luck
Old Jul 19, 2004 | 09:14 AM
Franco's Avatar
Franco
Cheers ZVH!
Anyone else
Old Jul 19, 2004 | 10:09 AM
R4N SS's Avatar
R4N SS
prob use normal mineral oil such as castrol gtx to run it in and then change it for synthetic oil once run in
Old Jul 19, 2004 | 10:23 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
pull out the fuel pump fuse too or you will flood it
Old Jul 19, 2004 | 01:36 PM
Franco's Avatar
Franco
Cheers all,
Fudgeass the puimps already disconnected!
So if i popped into the local car spares and just buy the cheapest thickest oil i can get, this will be good enough.. Don't want to damage her on start up.
What grade oil should i use?
Jay
Old Jul 19, 2004 | 02:59 PM
CabrioTurbo's Avatar
CabrioTurbo
use a good quality mineral oil in the car something like 10-50 will be good.. if not 10 40 will be ok but your oil pressure might be slightly low when its warm.
I wouldnt recomend you use synthetic oils at all in an RST engine
Phil
Old Jul 19, 2004 | 03:13 PM
Franco's Avatar
Franco
Once again Phil............... Well played!
Old Jul 19, 2004 | 03:20 PM
CabrioTurbo
lol just to give you a bit of reasoning behind what i said synthetic oil and im talking synthetic in the truest sense of the word, ie those oils which are completely man made (normally the very expensive ones ) can cause glazing of the bores on an RST i found this out the hard way as on my ol, old rst engine the bores were propely glazed... i did a bit of research and found out fully synthetic oil isnt good for an engine as old as an RST.
Old Jul 19, 2004 | 03:22 PM
CabrioTurbo
only other advise i can give other than that above is just to make sure everything turns by hand first and the engine doesnt bloody jam or something when turned over on the pulley! otherwise you will be well and truly fucked
track.focus'd
Aug 12, 2015 05:53 PM
Blown Hell
Aug 5, 2015 07:22 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
ginger1979
Jul 31, 2015 09:56 PM
