eXtreme Sports Channel - Gumball 2004 Part 2
Old Jul 18, 2004 | 08:36 PM
Jamz's Avatar
Jamz
Default eXtreme Sports Channel - Gumball 2004 Part 2
http://www.leetfighter.com/~jamz/200....2.avi.torrent
Tracker is up so the link to part 1 should be working as well.
Apollogies if the audio is a bit out of sync
Old Jul 18, 2004 | 08:40 PM
kjc300's Avatar
kjc300
can you download more than one torrent at a time????
Old Jul 18, 2004 | 08:43 PM
cool man, both downloading.....
Kev,
Use
http://azureus.sourceforge.net
To manage multiple downloads....
Dan
Old Jul 18, 2004 | 08:44 PM
Kev.H's Avatar
Kev.H
yup
Old Jul 18, 2004 | 08:54 PM
kjc300's Avatar
kjc300
cheers Dan!!
What's the best way to configure these things then??? Just changed the settings to unlimited, thats about it!!!
Old Jul 18, 2004 | 08:55 PM
kjc300's Avatar
kjc300
using bit tornado btw
Old Jul 18, 2004 | 09:34 PM
insane.cossie.driver's Avatar
it aint workin on my pc!
thaught by restartin my pc would of sorted it, but it still wont work
Old Jul 18, 2004 | 09:46 PM
Billabong's Avatar
Billabong
Jamz, will leave it to share/seed after it's finished as before. (p.s. are you using your own tracker?)
Old Jul 18, 2004 | 09:51 PM
Old Jul 18, 2004 | 09:54 PM
luke89's Avatar
luke89
Team HOTHOT!
dont work all i get is text file
Old Jul 18, 2004 | 09:55 PM
same here
Billabong's Avatar
Billabong
ICD you are you using a Bit Torrent client to download aren't you......?
Old Jul 18, 2004 | 10:00 PM
Jamz's Avatar
Jamz
Yes, it's my PC at home.
Old Jul 18, 2004 | 10:59 PM
Billabong's Avatar
Billabong
Use the link Dan gives above to download a Bit Torrent client, then you can use the link Jamz posted to download the file......it's not a 'normal' file download link.
Old Jul 18, 2004 | 11:08 PM
Part 2 not downloading, says it's queued!!
Old Jul 18, 2004 | 11:22 PM
Jamz's Avatar
Jamz
I'll give it a slap when I get home at 2am.
Old Jul 18, 2004 | 11:47 PM
Hardeep_Singh's Avatar
Hardeep_Singh
was this the onne that was shown on sunday 8:30 guys?
Old Jul 19, 2004 | 12:43 PM
timb551's Avatar
timb551
Hello mate quality work getting them up on the web. Just curious, why is there a speech delay on both editions?
thanks
Tim
Old Jul 19, 2004 | 12:45 PM
Spiky's Avatar
Spiky
anyone notice the advert for part 3 at the end
Old Jul 19, 2004 | 12:47 PM
Jamz's Avatar
Jamz
I had to encode the audio seperatly which introduced a slight delay. It was too much hassle to fix it so I didn't
James
Old Jul 19, 2004 | 12:54 PM
DaveEscos's Avatar
DaveEscos
aaarrghh!!
can some coont just upload it as an avi or mpeg to some webspace!!
Old Jul 19, 2004 | 01:44 PM
timb551's Avatar
timb551
Uploading now.........
Old Jul 19, 2004 | 02:05 PM
both parts downloaded, will fix the audio and share out on ed2k later tonight if I get time!
btw - shared out over 700mb on BT
Old Jul 19, 2004 | 02:07 PM
BlueSmoke's Avatar
BlueSmoke
PassionFord's crazy fool!
You get a text file if you click the link. Instead, copy it and paste it into your bit torrent client and that should start downloading.
Old Jul 19, 2004 | 02:17 PM
timb551's Avatar
timb551
cheers Dan, i look forward to that. ill cancel my upload then.
Old Jul 19, 2004 | 09:06 PM
Tried sorting the audio problem out without success
The audio for some strange reason it not consistansly out if you get me hence I can only get small section to sync up at a time. All I can assume is that some video frames have been dropped while capturing.
Old Jul 19, 2004 | 09:21 PM
Ish's Avatar
Ish
jamz on your capture prog is there not an option to lock the audio to the videostream while capturing?
this will mean even if you drop frames the audio will stay in sync!
Old Jul 19, 2004 | 09:44 PM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
Thanks for upping this one Jamz, hopefully i can get the first one sometime also.
Very much appreciated, mucho gracias
jessie_rs
Jan 5, 2016 01:16 PM
Kam B
Sep 24, 2015 10:40 AM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
andrewmctiernan
Sep 8, 2015 03:05 PM
jessie_rs
Sep 7, 2015 01:27 PM
