eXtreme Sports Channel - Gumball 2004 Part 2
http://www.leetfighter.com/~jamz/200....2.avi.torrent
Tracker is up so the link to part 1 should be working as well.
Apollogies if the audio is a bit out of sync
cool man, both downloading.....
Kev,
Use
http://azureus.sourceforge.net
To manage multiple downloads....
Dan
Kev,
Use
Dan
Jamz, will leave it to share/seed after it's finished as before.
p.s. are you using your own tracker?
Use the link Dan gives above to download a Bit Torrent client, then you can use the link Jamz posted to download the file......it's not a 'normal' file download link.
PassionFord's crazy fool!
You get a text file if you click the link. Instead, copy it and paste it into your bit torrent client and that should start downloading.
Tried sorting the audio problem out without success
The audio for some strange reason it not consistansly out if you get me hence I can only get small section to sync up at a time. All I can assume is that some video frames have been dropped while capturing.
jamz on your capture prog is there not an option to lock the audio to the videostream while capturing?
this will mean even if you drop frames the audio will stay in sync!
andrewmctiernan
08-09-2015 03:05 PM
