lost locking wheel nut key
Old Jul 18, 2004 | 07:15 PM
smartrs's Avatar
smartrs
Default lost locking wheel nut key
as above i have managed to loose mine has any one got any ideas on how to get them off as i need new tires
please pm me with any ideas
thanks in advance
Old Jul 18, 2004 | 07:18 PM
TrickyDicky's Avatar
TrickyDicky
can you put up a picture of which type it is and i'll tell you best way, usually though on most driving a socket on will do the trick, i do have some removers that have a left hand thread that bite in as you wind them on thus undoing nut.
Tricky
Old Jul 18, 2004 | 07:20 PM
smartrs's Avatar
smartrs
i'll try and sort a pic out
Old Jul 18, 2004 | 08:13 PM
woodz77's Avatar
woodz77
i had the same problem before mate i hand to smash a socket on to it . u have to use decent sockets like snap on or something cause ive tried with cheap ones and the socket has split down the side . bit of a pig to get the wheel nut out the socket though
Old Jul 18, 2004 | 08:18 PM
TrickyDicky
easiest way to get nut from socket is if nut type then use a wheel stud off mk4 esc etc, screw into nut, hold this in vice and tap socket off, if stud type locker youve smashed socket on then use a normal wheel nut to hold still whilst tap socket off. all the same thread M12x1.5.
Tricky
Old Jul 18, 2004 | 08:30 PM
smartrs's Avatar
smartrs
i will have ago at the socket trick tomorrow
Old Jul 18, 2004 | 08:56 PM
Zetec Andy's Avatar
Zetec Andy
better get the hammer and chisel out
Old Jul 18, 2004 | 09:26 PM
Stu.H's Avatar
Stu.H
how many people have this same problem?
we can sort u out mate
Old Jul 18, 2004 | 09:32 PM
smartrs's Avatar
smartrs
its a nightmare cos you cant keep the key in the car as that defies the object reallyso you put it somewhere safe and then you cant find it !! plus side is that i have found a wheel nut key for a car i had years ago
Old Jul 18, 2004 | 09:37 PM
TrickyDicky
if you dont keep key in car then what will you do if you get a puncture whilst out somewhere????????????
Tricky
Old Jul 18, 2004 | 09:42 PM
smartrs's Avatar
smartrs
that is true but whats the point cos the theving scum will find the key and have the wheels away still i've lost it has anyone got a solution they can sell me ?
Old Jul 18, 2004 | 10:02 PM
TrickyDicky
to be honest mate someone half clued up doesnt need a key, it takes us less than a minute a piece to remove them- its rare we get a car in with alloys and the lock nut key!
there a good deterrent for amateurs but thats about it.
Tricky
Old Jul 18, 2004 | 10:05 PM
smartrs's Avatar
smartrs
guess so mate but its bad that i cant even get them off my self you got something to sell me or do i need to find my local theif to get them off for me
Old Jul 18, 2004 | 10:11 PM
TrickyDicky
if it isnt the type with 4 dimples in then just drive a socket on and undo, the 4 dimple type are awkward on sierras as there hard to get socket on so we got an old key and knocked 3 of the dowels out so only 1 goes in, tap it on and undo, wont turn as located by centre boss on nut. the bigger od types like 20 and 21mm buy wheel lock nut remover sockets with left hand threads-mine cost Ł2.50 plus vat from warehouse.
if you were closer id say bring it round and i'll do it for you.
Tricky
Old Jul 18, 2004 | 10:17 PM
smartrs's Avatar
smartrs
it not got dimples it jus is a funny shape i can get a 19 mm socket on it but when you try to loosen it it slips it looks to be nmore of a nut then a bolt !! i'll try and get some pics up tomorrow if i have no luck removing it ! what warehouse you get it from ?
Old Jul 18, 2004 | 10:23 PM
TrickyDicky
if a 19mm socket slips then get some imperial/af sockets -youll find a suitable one! other way is with air chisel and pointed chisel.
Tricky
Old Jul 18, 2004 | 10:24 PM
TrickyDicky
if a 19mm socket slips then get some imperial/af sockets -youll find a suitable one! other way is with air chisel and pointed chisel. or worst case blow head off nut with gas bottles-doesnt do wheel much good though.
Tricky
Old Jul 18, 2004 | 10:29 PM
smartrs's Avatar
smartrs
i will have ago tomorrow i dont really wanna damage the wheel to be honnest as theres not a mark on them
Old Jul 18, 2004 | 10:35 PM
TrickyDicky
i was joking about blowing head off bolt! no reason why wheels should be marked- ive never marked one yet.
Tricky
Old Jul 18, 2004 | 10:40 PM
smartrs's Avatar
smartrs
well if i have no luck i'll give you a pm for more advice
Old Jul 18, 2004 | 10:42 PM
TrickyDicky
no probs mate
Tricky
Old Jul 19, 2004 | 02:31 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
just wondering what line of work u in tricky?? the uniform dosn't include a white an black striped jumper an a bag with "SWAG" written on it does it?
my brother managed to shear a locking wheel nut onto my cossie but luckily the wheel was scrap anyway, so i used a 5ft axe to smash the spokes, then cut the wheel off from around the hub with an angle grinder should have seen the neigbours peering out of their windows as I was swinging the axe at the cossie nosy fookers
Old Jul 19, 2004 | 07:59 AM
TrickyDicky
not quite mate, i run a breakers.
Tricky
Old Jul 19, 2004 | 12:28 PM
s1 cabby's Avatar
s1 cabby
I always use a 18mm double hex socket and bash that fooker on there!! Tbh so many pepole know how to take locking wheel nuts off theres no point in havin the really!!! (I only say this coz i had a set of alloys nicked and they had lockin wheel nuts on em )
Old Jul 19, 2004 | 12:42 PM
turbo man's Avatar
turbo man
biscuit + tin + gator grip = wheels off no worries.
ignore all other ways of doing it cos they are n00bs
Old Jul 19, 2004 | 03:30 PM
smartrs's Avatar
smartrs
its ok the tyre fitter that i'm getting the tyres off said they can get them off without damaging the wheels bit of a result
JK12
33
Apr 26, 2021 12:09 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
rst-s1
Aug 23, 2015 07:56 AM
