CAN YOU REMOVE CORE PLUGS WITHOUT STRIPPING THE ENGINE ?
Old Jan 6, 2006 | 08:58 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Default CAN YOU REMOVE CORE PLUGS WITHOUT STRIPPING THE ENGINE ?
as in on a engine already built up, at work they said to drill a hole and just pop em oit with screw driver,,,,,,,,,, but none of em have done it on there engines yet all they all seem to have only done it on proper pinto engines and so they never got worried as they was customers cars too
can i do it on my cossie engine or not ????
Old Jan 6, 2006 | 09:00 PM
DOO's Avatar
DOO
hammer and a screw driver job done.
Old Jan 6, 2006 | 09:05 PM
gurnE's Avatar
gurnE
Exactly.
Old Jan 6, 2006 | 09:06 PM
Ginge !'s Avatar
Ginge !
see that dont give me faith at all
the engine is 2k or 3k to rebuild and the way you remove em is with a screw driver and a hammer and refit with a socket
theres gotta be a proper tool i can buy as not even im that brave
Old Jan 6, 2006 | 09:08 PM
Physio's Avatar
Physio
Exactly.
What they said.
Old Jan 6, 2006 | 09:12 PM
gurnE's Avatar
gurnE
Stop being a tart
Easiest job in the world. Rip the old one out, whack the new one in.
S'not rocket science
Old Jan 6, 2006 | 09:14 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Is that how they are held in
Just pushed in....
Old Jan 6, 2006 | 09:17 PM
Ginge !'s Avatar
Ginge !
Exactly.
What they said.
how much mechanical work have you done to confirm that comment
( just asking as i know doo is a cowboy and gurnE rides a bicycle these days and built a engine using transit spares ,wanna have proper advice,,,,,,,,,, no offence guys )
Old Jan 6, 2006 | 09:18 PM
rstoughy's Avatar
rstoughy
Just pushed in....
Sure is
Just an interference fit so that frost can pop them out if the block freezes
Old Jan 6, 2006 | 09:20 PM
MAD EVO 4's Avatar
MAD EVO 4
Thats how ive always done them but always put a slight smear of gasket sealant round the edge before tapping back in,
They used to always be a popular job when i was a tech at Renault
Charlie Chalk
Unknown.
cheers
Old Jan 6, 2006 | 09:26 PM
DOO's Avatar
DOO
just to be safe wash out the water system after just to clear any crap out if your that worried.
why would you want to change them anyway not worth it if they anit leaking???
or you just being a bufty??
Old Jan 6, 2006 | 09:31 PM
Ginge !'s Avatar
Ginge !
ive painted on em and its anoying me,,,,,,, that and they aint shiney
Old Jan 6, 2006 | 09:33 PM
Damo V's Avatar
Damo V
What they said but IMO I wouldnt remove them... you wont see them when all built up anyway..
Gonna cause yourself more trouble than you need IMO
Old Jan 6, 2006 | 09:34 PM
DOO's Avatar
DOO
bit of wet and dry then and sore fingers or just hit the fookers out
Old Jan 6, 2006 | 09:35 PM
gurnE's Avatar
gurnE
Exactly.
What they said.
I'm also a qualified spanner wielder and IIRC replacing core plugs was the first thing I was taught at college aged 16
Old Jan 6, 2006 | 09:36 PM
Ginge !'s Avatar
Ginge !
mate ive taken the engine out, resprayed the engine bay,,,,,,, done it again as i wanted the wholes filling and then remade the whole loom
its been off the road for most of the year,,,,,,,,, i dont think there could be anymore trouble i can cause
Old Jan 6, 2006 | 09:37 PM
Ginge !'s Avatar
Ginge !
Exactly.
What they said.
see classic sign of a person with a drug addiction,,,,,, always a story
Old Jan 6, 2006 | 09:38 PM
DOO's Avatar
DOO
if the engines out i could even do it with my eyes closed just fooking change them.
PS. check there avab before ripping them out
Old Jan 6, 2006 | 09:40 PM
Ginge !'s Avatar
Ginge !
there available,,,,,,,,,im sure that theresa place in ashton thats got em stored away,,,,,,,,,, with everything else
Old Jan 6, 2006 | 09:42 PM
MAD EVO 4's Avatar
MAD EVO 4
what engine is it on bro
Old Jan 6, 2006 | 09:46 PM
Damo V's Avatar
Damo V
KA ZETEC
Pinto
Old Jan 6, 2006 | 09:49 PM
Ginge !'s Avatar
Ginge !
damo it WAS a pinto,,,,,,,,,,,, now ive messed with it its more HCS power
Old Jan 6, 2006 | 09:54 PM
Physio's Avatar
Physio
Exactly.
What they said.
Ginge - we used to sell rebuild RS's & sell RS parts for a living & i've changed quite a few of them in the past - such an easy job Just make sure when you put the new one in it goes in level
Old Jan 6, 2006 | 10:06 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
There is a tool for this. The same tool used for wheel bearings etc..
Old Jan 6, 2006 | 10:08 PM
Ginge !'s Avatar
Ginge !
i use a hammer and punch on them too
cheers for the hint on my manifold studs,,,,,,,,,, fooking class that
Old Jan 6, 2006 | 10:17 PM
Versus_Creations
Ask me a question!
But using the hammer and screw driver method can put them out of shape. The decent tool will hit the core plug even.
It is being a little fussy i know, but after building an engine up we can all do without the teething problems caused by cutting even the smallest corners.
Regards
Old Jan 6, 2006 | 11:09 PM
MAD EVO 4's Avatar
MAD EVO 4
I use a socket with an extension bar to keep it level as you knock the new in the hole
Old Jan 6, 2006 | 11:25 PM
DOO's Avatar
DOO
Regards
i would not use a a screw driver to re fit a core plug
Old Jan 7, 2006 | 11:34 AM
rstoughy's Avatar
rstoughy
Regards
Same here
Screw driver to remove old ones and a socket to fit the new ones
Roosie
Aug 15, 2015 08:09 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
MARKYMARKONE
Aug 2, 2015 09:33 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
