rs turbo heads are they the same as xr3i
Old Jan 6, 2006 | 01:46 AM
ford crazy's Avatar
ford crazy
Default rs turbo heads are they the same as xr3i
can i use a mk4 mfi xr3i head on a mk4 mfi rs turbo
are valves and cam the same
got to get my turbo on the road
the head has a faulty valve
and i have a xr3i engine
any one know
Old Jan 6, 2006 | 02:47 AM
sufsRS's Avatar
sufsRS
i believe cam is different and valves are sodium filled on a turbo
Old Jan 6, 2006 | 10:47 AM
Rick's Avatar
Rick
identical mate. cams are the same to, but the pulley is different on the turbo to give slightly more retard
Old Jan 6, 2006 | 10:50 AM
antony215's Avatar
antony215
Escort Rs Turbo
it's only the s1's that had sodium filled valve's
Old Jan 6, 2006 | 02:31 PM
sufsRS's Avatar
sufsRS
sorry il get my coat
Old Jan 6, 2006 | 05:22 PM
sexr3i's Avatar
sexr3i
isn't it
series ones had sodium valve seats and the RS turbo heads have round exhaust ports whereas XR's have D shaped ones.
Old Jan 6, 2006 | 05:46 PM
Rick's Avatar
Rick
Later heads had D shaped ports.... Not just 3i's
Old Jan 7, 2006 | 08:18 AM
DannyDK's Avatar
DannyDK
Im not shure that the cam is the same, i think it has lesser degrees and is made only for non turbo use, not sure though
Old Jan 7, 2006 | 01:13 PM
Wazzzer's Avatar
Wazzzer
cam is exactly the same as Rick said, its the pulley thats different
Old Jan 8, 2006 | 12:13 AM
ford crazy's Avatar
ford crazy
ok cheers so the only diference is cam pulley
Old Jan 8, 2006 | 11:40 AM
Rick's Avatar
Rick
Old Jan 8, 2006 | 04:07 PM
Cabstar's Avatar
Cabstar
What is the difference on the pulley?
Old Jan 8, 2006 | 07:15 PM
Rick's Avatar
Rick
It retards the cam timing a little on the RST
Old Feb 5, 2006 | 11:52 AM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Sorry for bringing up this topic again!
How can I identify the pulley from a RST? Parts number, diameter, etc?
Old Feb 5, 2006 | 12:10 PM
XR2's Avatar
XR2
S1 RST heads are exactly the same like RS1600i ones. Same ports, same height and so on . S2 ones had the same specifications but hardened valve seats and most S2 also had sodium filled exhaust valves!
The height of RST and XR3i heads is different, so thats why there have been different camshaft pulleys
Old Feb 5, 2006 | 04:30 PM
Rick's Avatar
Rick
PeterRST
RST its a KA pulley
Old Feb 7, 2006 | 10:32 AM
andre_k's Avatar
andre_k
the rs1600i used solid lifters, not hydraulic...
Old Feb 7, 2006 | 11:26 AM
XR2's Avatar
XR2
Sure. And a rougher cam, other rockers, other inlet valves, a blanking plate for the dizzy side, standard exhaust valves and so on. But I talked about the HEAD, not the internals!
Old Feb 7, 2006 | 08:21 PM
DannyDK's Avatar
DannyDK
When you talk about the pulley being different, what will happen if someone where to use a xr3i pulley on the RST engine, please break it out in bits for me, im a retard when it comes to understanding things in english, not that i dont understand the words but its different to picture, if you know what i meen
Old Mar 5, 2006 | 08:53 PM
paconassa's Avatar
paconassa
arent you all forgeting about the combustion chamber shape?
rst are heart shaped, xr3i are hemi...
go to norris motorsport to check this out!
Old Mar 5, 2006 | 08:57 PM
paconassa's Avatar
paconassa
www.norrismotorsport.co.uk
Old Mar 6, 2006 | 11:17 AM
JesseT's Avatar
JesseT
All injected CVH engines, including RST, had the hemi head. You can convert to the arse-shaped chambers as shown on Karl's website, but RST surely came with the hemi chambers.
Old Mar 6, 2006 | 11:58 AM
jonnyturbo's Avatar
jonnyturbo
RS turbo heads all have the hemi chambers. lean burn heads, with kidney shaped chambers only came on later carb model cvh's
Old Mar 6, 2006 | 11:59 AM
jonnyturbo's Avatar
jonnyturbo
oh, and the lean burn heads arent favoured for tuning.
Old Mar 6, 2006 | 01:15 PM
XR2's Avatar
XR2
Heart shaped heads were found on many later 1.4i's like the PTE.
They wouldn't be that bad after all for tuning, especially the ignition would work well with these heads but you need the right piston crown for this...
Old Mar 7, 2006 | 03:42 PM
paconassa's Avatar
paconassa
say that to karl @ norrismotorsport...
Old Mar 7, 2006 | 05:08 PM
SafeChav's Avatar
SafeChav
Fuck really ive got more pulleys than i can shake a stick at and i have no idea which one is the RS one i picked the cleanest one Any way of telling them apart???
As for the heads they are 100% the same as are the valves (which AREN'T soduim filled) and the cams.
See this link for some more info and also some comic reading :
https://passionford.com/forum/viewto...r2i+heads+same
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Marcus L
Aug 29, 2015 02:18 PM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 15, 2015 10:43 AM
