PC HELP NEEDED!!!!!!
Old Jan 5, 2006 | 11:01 AM
Physio's Avatar
Physio
Default PC HELP NEEDED!!!!!!
Whenever i use kazaa (or even have the programme open) my whole pc just slows down
No matter what other programme i use (whilst kazaa is open) it takes fookin ages to open up or do anything else on my pc, it even slows down my msn etc
As soon as i close the programme (kazaa) everything speeds back up again
Is there anything i can do to sort it out?
Any help will be apreciated
Thanks.
Old Jan 5, 2006 | 11:02 AM
rsnissan's Avatar
rsnissan
stop using kazza
get some more memory
Old Jan 5, 2006 | 11:04 AM
Physio's Avatar
Physio
Stop using kazaa
More memory?? Could that be the problem?
Old Jan 5, 2006 | 11:07 AM
Stu.H's Avatar
Stu.H
reinstall and memory
i'll sort it for ya if ya want.
Old Jan 5, 2006 | 11:08 AM
Physio's Avatar
Physio
Reinstall? Not again
I think thats gonna be about the 4th time you'll have done it for me
Old Jan 5, 2006 | 11:09 AM
MAD EVO 4's Avatar
MAD EVO 4
Kazaa carries alot of virus's
saffsta's Avatar
saffsta
Kazaa is dead do a web search for a p2p called bit comet version 6.0 its meant to be quite good
Old Jan 5, 2006 | 11:11 AM
rsnissan's Avatar
rsnissan
yes thats why i suggested it
hit ctl alt and del while its on and then go task manager and then to processes and see how much its using..............and go to peformance and see how much of the PC's resources are being used (available memory etc)
Old Jan 5, 2006 | 11:12 AM
Stealth Bomber's Avatar
Stealth Bomber
Memory.
Old Jan 5, 2006 | 11:14 AM
User 32922's Avatar
User 32922
kazza is cr@p, full of viruses, use something else
limewire
emule
bit torrent
etc etc
Old Jan 5, 2006 | 11:16 AM
MAD EVO 4's Avatar
MAD EVO 4
i use bit torrent its fast and clean
Old Jan 5, 2006 | 11:17 AM
Stu.H's Avatar
Stu.H
and monitored
AJ, is it windows xp you are running?
also how much memory is there in ur machine?
Old Jan 5, 2006 | 11:18 AM
KW-rscos's Avatar
KW-rscos
there are loads of things it could be, but why are you using Kazaa thought that was oldskool? Bitlord is better surely? like RSnissan says it could be memory so check your task manager, but also delete all your cookies and temp internet files cos the slow down pcs no end, and if there are files linked with Kazaa then that might slow down the pc. plus the main folder for Kazaa that store oll the downloaded files will take longer to open the more is in it, so organise those files aswell, as kazaa will use it in the background that might slow you down.
oh and finally get a good anti-virus but not norton, lol.
hope that helps
Old Jan 5, 2006 | 11:27 AM
BM08's Avatar
BM08
How much RAM has your pc got?
Shouldnt really slow it down at all unless you have a really old/slow pc
I run limewire on my pc and it doesnt effect it how it runs at all, even when im downloading 10 songs or somthing
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
