what exactley is wire ringing?
it's where a groove is machined into the block face around the bore ( a few mm away ) and a copper? ring is inserted. it helps the head gasket to seal better.
that's what i thought anyway
i don't know a great deal tbh about it, so probably best to wait for more replies. not sure what HG to use when wire ringing? on a cossie i presume it's designed for 611 as grp A cars were wire rung i believe?? not sure about others though
Originally Posted by leecavturbo
thought you ran no gasket with wire rung blocks ? but mega good surfaces required possibly 10RA
Wire ringing is not the same as 'Coopers rings', just for info.
I'll be going with my tuners recomondations.
They have also mentioned the cometic (im sure i was told the head and block need to be machined flat?!) but they said wire ringing maybe the better option
Originally Posted by bud-weis
like this
[img:640:480:578f80be9c]http://img.photobucket.com/albums/v303/charliesaff/Engine%20Build/P1010294.jpg[/img:578f80be9c]
charliesaff's engine i believe
That is called a rung bock, you'll need a cooper ring gasket also, this is where the fire rings are separate from the head gasket, the gasket costs roughly £250,
A wire rung block is slightly different, it has wire slightly embedded into the block a few mm from the bore
like this
[img:640:480]http://img.photobucket.com/albums/v303/charliesaff/Engine%20Build/P1010294.jpg[/img]
This is mine, it cost me £25 per pot to be done, by a very good local company to me. This (as Bill says) bites into the gasket to get a great seal. I would recommend it to anyone!
like this
I have more pics if anyone wants
deathrider666
Sep 28, 2015 06:12 PM
