CVH water pump
does it realy matter wot way the cam belt goes around the water pump and tensioner?
after fitting a belt i relised i put it on the wrong way around the water pump, but realy cant see any differnce either way it goes.
Okay Im not 100% sure BUT
1.I'd refit it the CORRECT way because if the belt jumps off any pulley the head will get 8 bent valve's += BIG repair bill for you!!
2 The pump may turn the wrong way with the belt on wrong and you could get overheating problems.
So if I wqas you I'd refit the belt on correrctly.Regards Micky
