car wont start
Old Dec 31, 2005 | 12:50 PM
s2 ben's Avatar
s2 ben
Default car wont start
my s2 is starting 2 do my head in now last week i was driving 2 work when the car started 2 pop and bang and judder only now and then not all the time on the way home it got more freqent then it jst died i new it had something to do with fuel so i called the aa he said the same any ideas please fuel pump is fairly new thanks
Old Dec 31, 2005 | 12:56 PM
Oranoco's Avatar
Oranoco
Check the plastic pipe from the top left breather filter to the base of the air flow meter. You only need a small leak from these to cause problems
Old Dec 31, 2005 | 01:06 PM
s2 ben's Avatar
s2 ben
will do mate the car will turn over just wont start the fuel pump not even priming but like i say it is nearly new would the fuel relay do this
Old Dec 31, 2005 | 01:07 PM
Oranoco's Avatar
Oranoco
If the fuel pump isn't priming then the first place I would look is the relay.
Old Dec 31, 2005 | 01:55 PM
s2 ben's Avatar
s2 ben
where is it is there any way to check apart from buying a new 1
Old Dec 31, 2005 | 03:04 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
The relay on a S2 is up in the drivers footwell, on the right hand side.
To check if it is the relay, bridge these 2 points on the relay's base with a piece of wire and 2 male spade connectors. (not the relay itself)
This will make the pump prime constantly. instead of just priming once to get pressure.
DO NOT drive about like this, as the relay is a failsafe in the event of an accident.
If the pump primes this will prove the relay does not work
(or if you know how to work a volt meter use that )
Old Dec 31, 2005 | 03:10 PM
SafeChav's Avatar
SafeChav
Sorry to but in, do series 1's actually have the same purple fuel pump relay as XR3i's and Series 2's? I keep seeing these "mega rare" series 1 relays on ebay and theyre completely different
Old Dec 31, 2005 | 03:57 PM
vroooom ptssssh
It Wasnt Me!
Nope, not that i am aware. My car has series2 fuel pump wiring for some strange reason. pics a bit confusing should of mentioned
Old Dec 31, 2005 | 03:59 PM
SafeChav's Avatar
SafeChav
Ah right ok, i just wondered thats all? I cant understand why the Series 1 had a different relay, the series 2 run the Purple relay, Ford do some gay things lol.
I'm with you, i used Series 2 wiring in my MK3 cabby so i also have the purple one, a lot easier to find aswell!
Old Dec 31, 2005 | 04:03 PM
vroooom ptssssh
It Wasnt Me!
i need a purple relay as it happens, havent got round to buying one
Old Dec 31, 2005 | 04:10 PM
SafeChav's Avatar
SafeChav
Ive got loads kicking about lol (most being the not working type ) i know ive got 2 good ones though, and i repaired this one lastnight, i could smell the unmistakable aroma of "burning fuel pump relay" one day
That pin was actually completely loose, it stuck it the plug on the car i had to remove it
Old Dec 31, 2005 | 04:40 PM
vroooom ptssssh
It Wasnt Me!
you can send your brocken ones to "DazC" and he will repair them and send them back if thats of help!
Old Dec 31, 2005 | 05:12 PM
SafeChav's Avatar
SafeChav
i can fix myself i think, just havent got round to it yet theyre simple enough, im sure ill do something with them when theyve all broken and i cant go out and play
I'll bear it mind though
That said they will all run the car, just don't prime, lol
JoeyBoyden
Jan 4, 2024 02:36 PM
Fordmad!
Sep 26, 2015 05:24 PM
Adam-M
22
Aug 10, 2015 10:46 AM
xr_craig
Aug 7, 2015 06:00 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
