ERST starting problem
Old Dec 30, 2005 | 03:33 PM
scott_j166's Avatar
scott_j166
Default ERST starting problem
it starts but runs on 3 so a hold the revs up on it then after about 30 seconds it clears and runs fine wot could it be the plug leads,dizzy or something?
Old Dec 30, 2005 | 04:15 PM
NUTS RuS's Avatar
NUTS RuS
Sounds like a dodgy plug when cold.
Is it always the same cylinder ?
Old Dec 30, 2005 | 05:38 PM
SafeChav's Avatar
SafeChav
If you've got your cold start valve connected might be flooding when starting, try disconnecting it and see how that goes.
Or as above get a new set of plugs.
Old Dec 31, 2005 | 05:58 PM
scott_j166's Avatar
scott_j166
not sure if its the same cylinder but will check it tomorrow,and wot 1s the cold start again so aknow wot am looking for
Old Jan 1, 2006 | 01:15 PM
SafeChav's Avatar
SafeChav
Its the little injector in the under side of the plenum (inlet manifold), got a blue plug on it, in between cylinders 2 & 3
Old Jan 1, 2006 | 03:24 PM
scott_j166's Avatar
scott_j166
cheers will try it tomorrow never got round to trying it today
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
