Sunroof problems!
Old Dec 12, 2005 | 02:12 AM
Poom's Avatar
Poom
Default Sunroof problems!
When I try and shut this properly I get clicking noises and the handle just spins!
I was told it is a problem with the cable? Just wondered how hard to replace?
Also, is the actual sunroof serviceable? Can it be taken out and then small parts changed or greased up to get it to be as good as new?
Thanks
Nick
Old Dec 12, 2005 | 08:21 AM
zippyobrien's Avatar
zippyobrien
to get to the sun roof you have to remove the roof lining, it will then costyou £200 to have a new rof lining put up. tbh the sun roof is proberbly rusted closed any way and there about 35o to replace. cant you live with just opening the windows??? lol
Old Dec 12, 2005 | 08:31 AM
ballin's Avatar
ballin
you dont have to remove the roof lining at all
it comes up and out the top, just need to remove some screws and clips from the inside.
the only thing with taking them out is its very difficult to get a good seal when you put it back
Old Dec 12, 2005 | 10:02 AM
adamS2RST's Avatar
adamS2RST
Don't look down the back when it's out
Old Dec 12, 2005 | 12:13 PM
Poom's Avatar
Poom
It is not so much that I cant get it to sit flush so the water is getting in! to be honest if I get it to sit flush I will just use the windows
Old Dec 12, 2005 | 04:07 PM
andre_k's Avatar
andre_k
mine does the same matey, it was ok until recently, now she just clicks and is very stiff...
if its stuck open, get a mate to push down/pull it closed (depending on position atm) whilst you turn the handle (it worked with me)
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
