Fitting a roll cage to ERST
Any tips or pitfalls i need to know, guy i bought it of said allow 6 hours with 6 to spare. Its a 6 point bolt in job by safety devices
Cheers PaulT
Cheers PaulT
1.Get a mate to help you,as its a tight fit.
2.Take you're time,be carefull and dont lose you're patience!!!!!
3.Have a fire extingusher handy when welding in the floor strenghten plates as the underseal will catch fire.
Regards Micky
Regards Micky
Do the cages differ from series 2 to series1 and with/without sunroofs? Looking to make some larger plates to spread the load as such, but thanks for the advice
I see from the siggy you look track bias so can i put a suspension question to you. In the wet/damp is it better to be softer on the dampers and harder in the dry.
Looking to do a few more trackdays next year might see you there.
Cheers PaulT
Cheers PaulT
I know that OMP make 2 different roll cages,1 for a sunroof fitted car and 1 without.,I dont know about other makes but would imagion they do aswell.When ordering youre cage tell them if you have a sunroof fitted.Also,some cages run tight to the bulkhead and need the dash cut at the ends,others dont,so ask questions before you order to see how the cage runs inside the car.Personnally it wouldnt bother me to cut the end of the dash,but other owners may not want too.I personally dont know if a cage would fit both a S1 and a S2,at a guess I'd be 90% sure it would,but again find out when ordering.
For a wet track you should soften up youre dampers and reduce tyre pressure a little.You will have to experiment with the pressures but around 5 psi less (when cold) would be a good starting point.Hope this info is off value to you,regards Micky
6 hours!!!!!!!! He's having a giraffe mate!! More like 6 days....they are a pain in the arse!!
Bascially [instuctions for a Safety Devices 6 pointer]:
Strip the interior [Front/Rear Seats/Rear Quarter Panels/Carpet/Soundproffing/interior clock/sun visors/sill trim]
Loosley fit the cage in place [you will need 2 maybe 3 people to do this without scratching it/the car]. It will be a very very tight fit. I.E. hard up against the dash/roof/A pillar/C pillar and rear arches.
Then push the mounting plates under all 6 mounting points and mark by scratching the paint.
Remove the cage.
Stip underseal from under mounting points
Weld plates into car
Drill holes for bolts as necessary [Will require you to remove rear wheels]
Paint and underseal as necessary
Cut carpet and refit
[At this point make sure you empty the glove box other wise you'll have to remove the cage once fitted to get your belongings out. Like I did
Fit cage and bolt in place
Refit trim around cage [you will need to modify rear quarters/front door pockets/sill trim].
Have a look at the pics:
Remove the cage.
]Fit cage and bolt in place
Thats looks the business, those piccys will help no end
Will be having ago in the near future at fitting mine, just a quick question do you spot weld the plates or seam them?
Cheers PaulT
Will be having ago in the near future at fitting mine, just a quick question do you spot weld the plates or seam them?Cheers PaulT
Oct 9, 2015 07:38 PM
saph in dorset
Aug 14, 2015 10:10 AM
