Feeling bad
well hes told me is was "sound" and was looked over by a mechanic of sum sort a blind one maybe ???
it looks like its been attcked by a obseive wire cutter every wire in that engine bay has been cut and wired back up with tape !! well nearly all the battery to altinator cable was the worse left hangind and welded it self to the turbo !
the fan was on constant which ive bin told could have been dun to stop it over heating
and he still insists it was perfect when i got it it definatlly wasnt boosting properlly coz i didnt just as i pulled away and thought it was strange
and they are lil bits like when i toke the rocker cover off the tappets were in bits broke and the lifters tightened down solid wrnog size nuts etc
there was a grinding noise from the wheel which has got worse so he must have know that parts of the engine ie head,manfold etc was lose and had play
enigine had 2 bolts holding it in !!!! thats it and a diff gear box
ok i mite be being a bit of a moaner but i have waited along time to work my way up to a rs paying shit loads for insurance etc and then get bumm fooked by this dude
he just could have been plain honest i would have saved a 200mile trip and being stuck with a shitter
sorri to moan guys im just bitter as i swopped a mint rs2000 with him and i fink he knows it to the rs2k need a tiny bit of paint work and a theromstat and a front break callper sorting which i clearly stated
you learn from your mistakes, why do you thik he wanted to swap?
thats why i never swap, its an easy way out for someone who doesnt want the hassle of people looking at his overpriced car and laughing, so he swaps it on ebay... part ex/WHY lol
body work looks sweet lil bit of rust on the roof but fine else where bin told needs abit welded underneth for the mot next month by the back near the tank and in the footwell
didnt have a reason cant remeber but i miss my completly reliable rs from before was a shraight swop
im just looking around now save my pennys use the bus and save for a desencnt one
Thats pish mate, a know how you feel cos I have been stung big time before. Don't loose faith though, I just bought an outstanding S2 with genuine 36k miles and everything to prove S/H old MOT's etc for Ł3500, so there are lots of bargains out there
In a way I guess its "sold as seen" or "swapped as seen" in your case
Sorry mate but I'd have given it a proper going over before doing the deal or get someone who knows what they are looking at! to late now I know! just break it up for spares and make some cash back if it's that bad!
very true adam but im not a mechanic and only my mate cam with me made the mistake of finking it was good because it looked clean ur spott on to be fair im a mug
I don't think your a mug, but whichever way you look at it, you live and learn
its hard when buying a new motor, or swapping in your case. you sort of get your heart set on it before you get there. and you do over look things and its not until you get it home, do you realise whats wrong.
i brought mine by only looking at photos, and my mates judgement. as it was quite a long way to drive just to view it. it payed Ł900 for mine with a engine that was blowing the oil cap off and not ticking over. me thinking it was either a blocked breather pipe, or blown rings, i said yes and sent money to my bro who brought it for me,
it wasn`t till i got it to my place and had a good look round it, i found out what it was, 2 cracked pistons
but i was told the engine was standard, which it turned out not to be, so i was lucky in away, that i had good news and some bad news when i brought mine.
with yours mate, if your having all these problems and you have had enough, then strip it.
but i was told the engine was standard, which it turned out not to be, so i was lucky in away, that i had good news and some bad news when i brought mine.with yours mate, if your having all these problems and you have had enough, then strip it.
If it was me, id keep it, TBH its not rocket science to take a rsturbo engine out and replace it, can be done in a day, theres normally lots of engines about, if its just a case of a headgasket change, its a piece of piss, At least if u fix it, it will be done proberly, and give u that piece of mind,
if not u could buy another and had the same problem.
also nowadays, rst's have lots of miles on them and require a rebuild at some point, so bite the bullet rip the lump out, buy yourself a diesel for the winter, a build a good solid lump.
If it was me I would find where he is and go up with the boys and come back with the rs2k. If you want it sorted we can go and find him. Most be something on the paperwork.
yeh i kinda had my pants pulled down aswell for the same thing, im jus fixing mine slowly tho, and at the end of the day least i know everything is done properly. Theres also nothing that you cant get for these motors, good experience doing it yourself aswell! is that your rs in the pic jay?
to be honest mate i was sold a shitter a few years ago looked clean on the outside and paid Ł3000 up front without even looking under the bonnet thats how badly i wanted a turbo but the gearbox went within a month, the sills had rotted away basically the whole car was a rot spent ŁŁŁŁ trying to get it sorted out but their were always problems with it at the end sold it for just a grand but now i have a clean rst which i looked at properly before buying it you always learn from your mistakes
save up about 1500 quid, get your self a fully reconditioned unit from power enginering or another reputible company, switch to efi (for reliability although not 100% necessary) get it all in and running about 200 bhp (this seems to be a reliable figure.)
and enjoy the car.
with 1500 you could proberbly get a 2.0 zetec with lower compression (this can bedone by machining the head) and running your existing management and turbo.
if your loom foocked get a replacement at Ł100 max.
the best thing about the rs is its so simple, im still at school, never been to a mechanics coarse or anything, and ive changed rs engines and done nearly every engine job on one apart from rebuilding the bottom end and ive done this with knowlage ive picked up over the years and a hynes manual.
give up on your current shite engine and get a new one in !!!!!!!!!!!!
and enjoy the car.
I'm the bad guy that swapped with jay that your all talking about.
He went out in the car when we swapped
There was nowt wrong with it as I drove 200miles to meet up with him
All I've had off him is this is fucked that is fucked most all service parts ie fuel filter that was changed 1 month before he got it
it was regauly serviced using mobil 1 never ratled smoked or never fucked about not holding boost.
He fucked about with the timing so this could be the cause of the misshap he told me this himself in a pm.
Ive seen the advise people have given him on here and he has'nt listened to any of ya about getting the timing sorted.
I've had 3 Rs turbos so have had a bit of experience with them alright I'm no mechanic but you know when your car is fucked don't ya!
As for the scrapping it was rear brake shoes I told him this on the day.
Don't also believe he swapped a minter because the RS2K was also full of faults too.
But life goes on.
As for the reason for swapping the RS2K was my old car!
I would have bought it off him any way if he did'nt want to swap.
But in my eyes he got a better deal as the S2 was worth more money anyway
I'm sorry things have'nt gone to plan for him but thats life of owning an RS turbo
Just out of intreast though the people that think they are big and hard that are saying Shove it through his window and we must know where he lives can shove it up there arse as at the end of the day Jay wanted the car and he chose to swap.
But he wants to make his mind up whats wrong with it though as 1st its the dizzy then the fan then the head gasket otr thermostat and now he has just informed me it was the turbo at fault
Yes I feel he has'nt had the best of look with it and I would'nt want to wish it upon any 1
But at the end of the day Jay wanted the car Badly
But life goes on.
Now whos speaking shit!!
I thought it was fucked and did'nt run!!
http://cgi.ebay.co.uk/1989-FORD-ESCO...QQcmdZViewItem
Originally Posted by rs tommy
how cums you've converted back to a rs2000 sean, the rs looks sweeeet!
Was'nt too bothered about swapping though as I would Have bought it off him and kept the turbo anyway.
Just always liked my white RS2K I suppose
There was none of the probs wrong with it when I owned the turbo if there had been I would have told him
As you can see from his ebay add the car ran perfectly in his own words.
Originally Posted by T28 RST
You must have a good idea where he comes from and maybe even an address, go round to his door and have a talk with him
Im sure he will see sense then
So less of the clever talk.
