Car wont start
When turning the key, car tries to start but wont ignite. Was fine on Sunday then later on in the day it just wouldnt start. I thought it was the leads so i bought a new set of Magnecors (not cheap!) but it still wont go. Any ideas?
Na it only goes on one way does it not? It clicks into place if you spin it around? ie- theres a wee slot that fits into the cap itself. Would it still spark if it was on wrong?
ignition timing. . !?
fuel pump prime?
got spark still?
fuel pump prime?
got spark still?
did ou refit the dizzy at exactly the same timing it was at before you took it off for a new one?
check breather pipes are all connected, ecu, rocker cover, block, metering head and they are not blocked.
metering flap bobbing up and down when turning over? try when someone is turning it over, hold the flap down 5mm and see if it starts!
still not starting?
check fuel going to injectors.
take injector out, turn it over and get someone to press down on the metering flap to see if fuel spray's out.
was the fuel set up when the ignition timing was done?
The sensor ontop of the dizzy (black) think it's called a "hall sensor" can also be fragile, if nocked about or move dout of place it will not start!
still not starting?
i had a problem like this on my old RS turbo, the fuel gauge was reading i had fuel, but i was empty, take the main fuel pipe off the fuel filter, put the end in a milk bottle or something, and turn the car over, see if your getting fuel being pumped up to the filter.
and dont do what i was doing, you think you have fuel as when the pump primes, it puts what little fuel you have through the pipe, you need to crank the car over to make sure theres constant fuel when engines turning over
im guessing your ignition timing is out did you sort this when you fitted the new dizzy
s1_turbo, yep that's the flap im talking about.
RST MFI engines work off vacuum (with std breather) the engine vacuum sucks the metering flap down when turning over if their is a leak it wont go down when starting. If your oil cap is off it wont start.
Put a new metering unit on, fuel definitely getting to injectors and definitely getting a spark (i took it into Ford where i work!) but it still wont start. It turns over but just wont go. The fuel just floods the plugs. When cleaned up they still get good sparks. Would it still do this if my immobiliser was goosed? I got a Clifford 300. Its doing my head in now i want to put a match to it
The mechanics were at it again today - still not going! Definitely getting fuel and spark. they cant figure it out at all?
The metering unit flap goes up and down now and fuel goes to the injectors but just floods the plugs. They disconnected the cold start valve to see if that was affecting it but to no avail! Its really worrying me now
hi you sure that the HT leads are in the right places on the cap ????????
and as said make sure all brathers are ok and the oil cao is on right as i found this out the other day when my cap poped off and it wouldnt idle or start with out holding my foot down
I cant see why it wont start, seriously think the ignition timing is out, if it is it wont start.
immob usually cut's fuel or spark or starter.
try holding the metering flap down 5mm when someone cranks it over, how about getting a tow and see if it'll start from that, atleast if it does you'll know it does run.
After SEVEN hours in the workshop they discovered the leads were on the wrong way
I put them on when i got the Magnecors!
It ORIGINALLY wouldnt start cause one of the leads ends were broken but i fooked it completely by putting the new ones on wrong. Teach me never to touch my car again
cuz ive had mine off, an i cant get any juice out the metering unit to the injectors !!!!!!! plz reply asap
JoeyBoyden
Jan 4, 2024 02:36 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
