abs test on sierra
Old Dec 6, 2005 | 04:06 PM
xr4x4rs's Avatar
xr4x4rs
Default abs test on sierra
was there ever an description on here about how to test the abs system on the sierras
ive got a sensor down but dont dont know which one and dont know where to start to test the sensors
aboviously would like this working as its crap roads at the minute and im locking up everywhere lol
thanks
Old Dec 6, 2005 | 05:28 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
not much help, but try a search on here, been loads of discussions on ABS recently, you might just find something useful.
There is nothing conclusive in those discussions that I know, however, there have been a few suggestions of contributions from some in the near future, keep your eyes peeled
Old Dec 6, 2005 | 05:31 PM
rsnissan's Avatar
rsnissan
get a multi meter on the sensors one by one and spin the wheel to see which one is not working
Old Dec 6, 2005 | 05:35 PM
boXXer's Avatar
boXXer
GASH!
i asked this a while ago. Not sure how to do it either. Think stu is doing a essay soon.
Old Dec 6, 2005 | 05:37 PM
rsnissan's Avatar
rsnissan
have you tried testing them with a Multimeter then?
Old Dec 6, 2005 | 05:46 PM
boXXer's Avatar
boXXer
GASH!
nah, only found out how to do it the other day.... i think.
Old Dec 6, 2005 | 05:48 PM
xr4x4rs's Avatar
xr4x4rs
what settings on the meter
continuity
do i disconnect the sensor and test it that way
or leave it connected and test it but what setting?
Old Dec 6, 2005 | 05:57 PM
rsnissan's Avatar
rsnissan
You need to set it to read in Mili-amp disconnect the sensor, connect the two electrodes from the multimeter into the the two pins in the multi plug of the sensor (not the ABS loom )
Then rotate wheel (after jacking up car ) as the wheel spins the Check for deflection on multimeter. Check the scale on the meter or switch to one that gives a deflection when the wheel is spun. No deflection = faulty sensor.
*Edit* I wrote Mili-volts instead of Mili-amps
Old Dec 6, 2005 | 06:28 PM
xr4x4rs's Avatar
xr4x4rs
right so basically
i need to see if theres a reading on the sensor when i turn the wheel
but surely i wouldnt get anything from them as there is no power to them
hence why i asked if it was a continuity test as it would give a sound if it was working
do you know what sort of reading they should be
what if they all read but all different readings
totally to confuse the issue as its going to be a pain in the arse as its 4wd with 1 jack and no axle stands at the minute
Old Dec 6, 2005 | 08:11 PM
rsnissan's Avatar
rsnissan
Originally Posted by xr4x4rs
right so basically
The ABS sensors work on the principle of magnetic induction. The sensor consists of a magnet mounted in close proximity to a toothed "reference ring" that spins at wheel speed causing a "sine wave" (a low-voltage rhythmic pulse) to be generated by the magnet. Your picking up this pulse on the multimeter
Other than that yes the multimeter will read something (which is all you need to know to see if its working) it will either read or not.
As for the 4x4 thing take it out of gear to spin the wheels
Old Dec 6, 2005 | 08:29 PM
xr4x4rs's Avatar
xr4x4rs
right ok
will get this done tomorrow
thanks mate
Old Dec 7, 2005 | 12:19 PM
xr4x4rs's Avatar
xr4x4rs
ok
ive just tested te sensors as you mentioned mate
im not getting anything on all 4 when i turn the wheels
the only thing that flashes is the minus signal when i turn the wheel
not getting any numbers and all 4 wont of gone down like that surely
the meter is set to the black cable in 200ma socket
and then set to 200m on AMPS DC
is this right
Old Dec 7, 2005 | 12:43 PM
rsnissan's Avatar
rsnissan
Try setting it to voltage then, something low....................I did this AGES ago on another car and i dont have the multimeter and car to hand for a couple of weeks to have a play!
If nothing is coming up, check the resistance across the two pins. Fried sensors tend go open circuit as the fine wire at the coil end melts.
Old Dec 7, 2005 | 12:45 PM
boXXer's Avatar
boXXer
GASH!
well, if ya find out let me know as im gunna do mine soon.
Old Dec 7, 2005 | 12:52 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you can't read a current like that - a current can only be present if you have a voltage across a resistance - and you've disconnected the sensors from everything
Old Dec 7, 2005 | 12:54 PM
rsnissan's Avatar
rsnissan
ok aside from V=IR what would i have picked up when i was doing this then?
just seen this on the net so seems like its has to be set to voltage AC then give that a shot
"connected to both terminals, select "AC Voltage" and spin the wheel by hand. You should see at least 100 mV, with voltage picking up as wheel speed increases. If you don't see this, the sensor needs replacement."
Old Dec 7, 2005 | 03:16 PM
xr4x4rs's Avatar
xr4x4rs
right stil problems
thought i solved it got the abs light to go out but until i hit 20 - 30mph the abs light comes on
now before i changed a sensor the abs light was on instantly now it goes out after 20secs as it should be then comes on when i move
anymore ideas
how much are the sensors new from ford?
Old Dec 7, 2005 | 03:38 PM
foreigneRS's Avatar
foreigneRS
Testing the future
so I = V/R and as V is quite small and R is quite large, I is really quite small
Old Dec 7, 2005 | 05:43 PM
frog's Avatar
frog
Nick, unless I am mistaken (my university days are in a dim and distant future), the rotation of the wheel will create a small alternating voltage due to the magnetic nature of the sensor (like a dynamo).
The ammeter bit of a multimeter is in fact a very low value resistance across which a voltage is measured by the meter. Using the V=IR formula, the meter turns the voltage measurement into a current since it knows the value of the resistance.
So the resistance in the ammeter will enforce a small current to be generated, but I am not sure it would be of any relevance as it would be the only part of the circuit (probably what you meant).
The purpose of the meter's resistance in a full circuit is to introduce as little disruption as possible (hence its small value as it is wired in series), in this case, it's the only resistance, so by definition it is altering the circuit significantly.
Measuring voltage makes a lot more sense imo, which is what andy said afterwards
Old Dec 7, 2005 | 05:58 PM
rsnissan's Avatar
rsnissan
Indeed Greg...........all my physics at uni has long evaporated from my head so cant think it through logically
But I promise you will get a reading of some sort. Its annoying that i am not am not able to try it on my car and confirm the procedure one way or the other as i am away from the car at the mo until the weekend
Old Dec 7, 2005 | 07:57 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you could both be right, my university days are also long behind me.
off out now, to try the new honda civic - looks wicked
Old Jan 3, 2006 | 05:53 PM
boXXer's Avatar
boXXer
GASH!
Right, gunna have a go at this tomorrow. So what settings does my multi-meter have to be on? As im SHITE at electronics.
TPM961
Jan 15, 2018 10:50 AM
nico12
Dec 31, 2015 04:42 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
cossiestu
Sep 19, 2015 05:19 AM
hopper350
Sep 4, 2015 12:53 AM
