cheap cvh engine, must be good cond
ideally from a carbed cvh, as long as not efi, as heads differant.
would like to be able to see it running, or if cheap enough, not ness.
just the block + head needed...
I've got 1 matey, its a xr2i engine (i know you said no efi, but i had this engine in my carbed xr2 for 6 months and it was fine) it comes with a plate to bolt between inlet manifold to block injector holes, its also fitted with anti pump lifters and double valve springs (both Kent items)
£50, you'll have to collect it though...............
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Red_bull
Aug 9, 2015 08:34 AM
