whats the cost of building a ZVH bottom end??
Please can someone help me out.
my bottom end on my Turbo is prity much fooked, its cracked 2 pistons and the con rods dont look to healthy,
so i have been pricing up how much a set of low comp pistons are to replace mine, and a set of new con rods and a re-bore just be be safe.
the pistons are £400
the con rods are about £100
re-bore about £80ish
so i recon im looking at about £600 to re-build my bottom end. so if the standard CVH bottom end is going to cost this,is it worth going down the ZVH route instead.
so what i need to know is how much roughly is a 1.8 zetec bottom end going to cost to have built in parts and machining.
i dont want to go 2.0l really, 1.8 is fine for me.
cheers
cheers
Ive got a 1.8zvh, u could build one for under £1000, well I did with new pistons etc etc, It really depends on how far u want to go with the engine as u will have to upgrade clutch/gearbox
its just a matter of, do i build the cvh bottom end back together, or build a zetec bottom end.
Originally Posted by essexrsturbo
whats the point of building a 1.8?
1 is that you can use the standard CVH headgasket on the 1.8
and
2 i dont want to put to much torque throw the gearbox, as there not the stongest of gearboxes on the cvh unless you go buy a uprated box
In my opinion, I would build a zvh they are more reliable than standard cvh bottom ends, But if I was to build another 1, it would be a 2.1 with vauxhall 16v mahle pistons as it costs about the same
So you cant really compare it to a standard bottom end
if both r built right both r just as stong as each other
THATS WHAT I DID AND MELTED NO3 PISTON
BIN THE STANDARD PISTONS ,IVE JUST FITTED ACCRILTE FOGED 1S 400 NOTE BURTON POWER AND FULLY REBUILD BOTTOM END FOR UNDER A GRAND
will the standard con rods be up to 200bhp on the standard zetec??
i got standard rods
JK12
33
Apr 26, 2021 12:09 PM
