S1 help please . . .
Don't do it, leave it how it is
All the people ditching Piper cams for standard cams seems to be the right choice right now
piper cams seem to be made of jelly
If you want power improvement get a better intercooler, the standard item is wank, you will also probably find that when you remove it the sides will be blown out slightly!
As for cam, the standard cam is fine for what your car is running why change it when its running OK.
i would recommend a pro alloy intercooler, i have a front mounted one ,
but if your not wanting to play with some of the front end (cutting out of some)
then just get a standard replacement, they are 16mm thicker IIRC
dry, standard cams are said to last 60k, so there is chance
that it has already been replaced, your car done 85k or so aint it?
i looked at your clocks one day and seem to remember it being round that
figure.
figure.
Go for a GRS or other prooven or tested product, Pro Alloy are just not cut out for RST applications, Cossie's have no issues - just don't do it on an RST
well 21 psi with my pro alloy one and no problems
I run 25psi peak 22psi held
My GRS never once had a problem, NEVER
Originally Posted by dry
The extra BHP you will get with a cam is hardly worth worrying about!!
If you want a guaranteed increase in power, get a better intercooler, if your only planning on keeping the car at 15psi ( stage 1) then most after market intercoolers will be fine, its only when you start getting higher than 1 bar you need a more efficient cooler.
