suspect head gasket has gone
Old Dec 3, 2005 | 09:03 AM
JimmyFlo's Avatar
JimmyFlo
Default suspect head gasket has gone
mornin ppl.
just been out on my rs fitting my vent plates and noticed the water was low. so i whipped the header tank lid off and it had some mayo on it. checked the oil and that was fine. the head gasket has gone on this car before so could it be that it has residue still in the system?
Old Dec 3, 2005 | 09:09 AM
adamS2RST's Avatar
adamS2RST
Is there oil in the water? Is it over heating ?
Old Dec 3, 2005 | 11:50 AM
SafeChav's Avatar
SafeChav
unlikely to be from before, if it was you should of noticed almost straight after.
As mentioned above have you checked that?
I'd get the compression tester out and do a quick check aswell, can tell a lot from one of those. Better finding its gone sooner than later, as with all these things.
Old Dec 3, 2005 | 02:07 PM
JimmyFlo's Avatar
JimmyFlo
its using a little water but that could be a leak as the hoses aren't brilliant there doesn't appear to be oil in the water just mayo and the oil is absolutely fine. it only gets hot when standing but no more than usual. oil pressure is good and the water is pressurising so i dont know.
Old Dec 3, 2005 | 02:51 PM
mantamark's Avatar
mantamark
was the head skimmed when it was done last time?
Old Dec 4, 2005 | 09:13 AM
JimmyFlo's Avatar
JimmyFlo
head was fully rebuilt mate and skimmed yes.
Old Dec 4, 2005 | 02:09 PM
RST Ski's Avatar
RST Ski
have you tried a block test?
or pressure test on the cooling system?
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
pie-face
Sep 15, 2015 10:43 AM
