Megasquirt V3
Old Dec 2, 2005 | 10:06 AM
JohnnyB's Avatar
JohnnyB
Default Megasquirt V3
I am thinking about buying the above. my engine will be turboed at some point but not now. looking at Megasuirt it seems nice and simple I can get rid of my MAF and still use my edis 6 so it seems great so I can mess about with mapping in N/A mode.
why is it so cheap compaired to other systems? it seems have the same features as systems 5 times the price.
Help
Old Dec 2, 2005 | 10:09 AM
Its cheap because its enthusiast designed and built so no one is making lots of money on it and because no support has to be present for it that costs money cause its enthusiast supported as well.
Its a very good idea when cost is an option, but be careful which one you end up with, some of the early ones were an 8*8 map and even if you REALLY know what you are doing with setting load site break points you are going to struggle with only 8 points!
I dont know enough about them to tell you which ones have which map though, i would imagine that the V3 is ok though.
Old Dec 2, 2005 | 10:11 AM
big_wig_074's Avatar
big_wig_074
because you build it yourself mate,its not sold as something from a tuner,its a DIY thing with freeware etc....theres a nice website forum like this for it!
Old Dec 2, 2005 | 10:14 AM
JohnnyB's Avatar
JohnnyB
the cost built up
which are very good
If you have EDIS, then you are half way there. Assuming its MAP based
>EEC, then a V2.2 has all you need on it.
>Ł120 for the kit of parts Ł170 built and warranted.
>The V3 has a few nice bits on it, but is Ł45 more as a kit and Ł60 more
>built.
Old Dec 2, 2005 | 10:17 AM
Go for the latest version IMHO
Old Dec 2, 2005 | 10:19 AM
JohnnyB's Avatar
JohnnyB
I think I will buy the v3 built its only 200 ish notes
thanks chaps if anyone can think of anythink else which could cause problems please tell me before I buy
thanks
Old Dec 2, 2005 | 10:39 AM
Garage19's Avatar
Garage19
Megasquirt is great. Go for it. I find using the relay board makes wiring alot easier.
The msefi forum is very helpful and they will be able to solve any probs you come up with.
Old Dec 2, 2005 | 10:49 AM
JohnnyB's Avatar
JohnnyB
cheers mate have you got a link to that site
cheers
Old Dec 2, 2005 | 10:50 AM
foreigneRS's Avatar
foreigneRS
Testing the future
go for it johnny and let us all know how you get on.
i was thinking of going that route with my v6 4x4 estate, until i needed the sheel for my cossie bits and got rid of the boat anchor.
now thinking of junking the carb from my 1.1 fiesta and converting it to efi and maybe playing around with the ms system.
Old Dec 2, 2005 | 11:05 AM
Garage19's Avatar
Garage19
cheers
Here you go.
http://www.msefi.com/
Old Dec 2, 2005 | 11:06 AM
Sunil_FiestaRS1800's Avatar
Sunil_FiestaRS1800
Ive been considering megasquirt aswell for my na engine but thing i have no mapping experience at all. I know whats involved and im very good with computers/programs etc as im a programmer but i wouldnt wanna blow my expensive engine up. So not sure whether its worth it.
Is it gonna be really easy for me to kill my engine if i fuck it up?
Also i take it your best off hooking up a wind band lambda to properly map it .
Old Dec 2, 2005 | 11:13 AM
Garage19's Avatar
Garage19
Yes, you do really require a wideband for tuning.
A n/a engine is a good place to start learning as it won't melt itself so quickly if you do get it badly wrong.
Old Dec 2, 2005 | 11:30 AM
SapphyMike's Avatar
SapphyMike
hmmm, i guess though you really ought to have some experience engine wise, etc to map this?
Old Dec 2, 2005 | 11:57 AM
Jamz's Avatar
Jamz
Where were you planning on ordering from if you don't mind me asking ?
James
Old Dec 2, 2005 | 12:08 PM
JohnnyB's Avatar
JohnnyB
I found this guy on a web site fook knows which one and he seems to be the britsh dealer
bill@shurvinton.fsworld.co.uk
Old Dec 2, 2005 | 12:12 PM
Garage19's Avatar
Garage19
Not THE british dealer as there is no such thing.
Have dealt with bill before. Very genuine trader. Has supplied a large amount of the westfield/kitcar market.
Old Dec 2, 2005 | 12:34 PM
Frogford's Avatar
Frogford
I dont know anything about MegaSquirt but do remember a fwe peeps on Turbosport having no end of troubles.
Link here :
http://forums.turbosport.co.uk/bbs/s...1127423&conly=
As I said I havent got the foggiest what its all about, !
HTH
Old Dec 2, 2005 | 12:48 PM
Garage19's Avatar
Garage19
That turbosport thread is refering to megajolt which is a seperate ignition only system. Not megasquirt.
I have used megajolt before as well and had no problems with it.
See next months Fast Ford for a feature on a white 3dr with a pinto i fitted it to.
JesseT's Avatar
JesseT
There seems to be a lot of confusion here. The v3 you are talking about is only the board revision and therefore has the same potential as the earlier v2.2 board. You also don't have to worry about the old 8x8 map versions because it's a question of only an old software version. You can update it in a minute from the web without a programming device. The real choice is whether you want the MS-I or the MS-II processor. The MS-I has more feathers developped to it and therefore has all the whistles and bells, but it is limited by the older assembler programmed 8-bit processor. MS-II has a much better processor but is only starting it's evolution and therefore doesn't do much more than controlling the injection and ignition, yet.
Old Dec 2, 2005 | 12:52 PM
Garage19's Avatar
Garage19
Jesse, while we are on the subject of megasquirt. What have you found is the best method for getting your accel enrichments right with the accel wizard?
What figures do you use in the v/s colum?
Old Dec 2, 2005 | 12:58 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i believe that alex (J871yhk) can supply ms stuff
Old Dec 2, 2005 | 01:14 PM
JohnnyB's Avatar
JohnnyB
JessT all I need at the moment is fuel and ign.
It realy sounds good to me I think I am going to buy from Bill?
Old Dec 2, 2005 | 01:46 PM
JesseT's Avatar
JesseT
Garage19:
for ~380cc injectors in a 1.6CVH with efi throttle housing and potentiometer:
100%
MAP based
cold accel multiplicator 130%
accel time 0.5s
0.781 v/s threshold
2 v/s -> 0.1ms
4 v/s -> 1.5ms
8v/s -> 2.5ms
15v/s -> 5.0ms
These values are not in any way finetuned as I haven't found them critical or overly important.
Old Dec 2, 2005 | 07:01 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Very underestimated peice of kit, those who know a bit about engine management/mapping see its potential for project engines and enhancing one's learning.
Often mocked by chequebook racers as its "cheap" "diy" etc
I'll be shortly assembling a MSV3 (used with EDIS), to have a play with
Red_bull
Aug 25, 2015 06:27 PM
Matthew_M
Feb 18, 2007 09:31 AM
1.8 esc
11
Jun 22, 2006 12:48 PM
16vzetec
Jun 2, 2006 01:26 PM
Mad Professor
Jun 28, 2005 05:17 PM
