stage 2
Old Nov 30, 2005 | 10:57 PM
turbodaily's Avatar
turbodaily
Default stage 2
ive just got hold of some 701 injectors and collins 195 chip for my ofab frst,im currently running 10psi on 165 chip,could i fit the stage 2 chip/injectors and run around 10psi without getting her setup for a week or 2 or am i asking for trouble??
also do i need cossie fuel pump to run the stage 2 chip/injectors or not??
engine spec:
1.6 running t25 turbo/tubular manifold
165 chip
cvh35 cam/vernier
lighten/balanced bottom end and flywheel
low comp accralite pistons
4 paddle clutch
pace cooler and rad
cheers
Old Nov 30, 2005 | 11:25 PM
bud-weis's Avatar
bud-weis
Football Cwazy
if you are only gonna run the 10 psi you are already running then you will see no gain by fitting different injectors and chip.
the standard fuel pump if working correctly should be ok for about 200bhp or slightly more, but for around Ł100 you could have an uprated escort cossie pump from FSE, go for the one advertised as 350bhp capable, although in truth it is not capable of this at all on your fez, but will be fine at the power you'll be running.
then take the chip and injectors to a tuner and have them fit them and carry out a full management setup and on boost fuel check, probably cost between Ł120 and Ł150 plus a bit extra to fit chip and injectors.
the beiges are generally safe for around 16-18psi, which with the mods you mention will see you past the 200bhp mark
Old Dec 1, 2005 | 08:14 AM
turbodaily's Avatar
turbodaily
thanks its been setup before at power engineering on the current spec and made 185bhp so hoping to push it past the big 200bhp..
im not too sure if i HAVE TO run a cossie fuel pump or not,my mate was running pretty much the same setup as me but with a hybrid t3 and hes still using standard fuel pump... i was told standard pumps are good for 200bhp and maybe a little bit more aswell by someone else.im planning on running 12/13psi as i wanna keep it fairly reliable due to using her every day.
is there anyone on here running stage 2 with standard pump??
cheers
Old Dec 1, 2005 | 11:29 AM
bud-weis's Avatar
bud-weis
Football Cwazy
i used to run 230bhp on a standard pump, in all honesty there was no real reason to change it, i just figured it would be better to use one that isn't maxed out, it only takes something silly for the pump to lose some of it's flow.
Old Dec 1, 2005 | 01:21 PM
Scottish Greg's Avatar
Scottish Greg
I would get a much better intercooler as well. The Pace one isnt much better than a std Ford one.
Old Dec 1, 2005 | 02:48 PM
turbodaily's Avatar
turbodaily
ive just been on the phone to power engineering,he said 16 psi upwards you ideally need cossie pump,but anything up to 15psi is fine on standard pump. booked it in for tommorw on the rollers,ganna fit the bits in the morning and cruise her over to the lads
not taking no risks
Old Dec 1, 2005 | 04:16 PM
Oranoco's Avatar
Oranoco
My FRST is running 15psi on its 701's and it was enought to get the old girl to 207bhp on Engine Advantages dyno
On not taking the risk. Too many people chance it and it usually ends in (expensive) tears.
On a downside my turbo let go with =in days of the 195 conversion Ahh well it paved the way for the spangly T3
JK12
33
Apr 26, 2021 12:09 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
A.t.p
Sep 29, 2015 05:04 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
