Coilovers
Old Nov 30, 2005 | 12:49 PM
JimmyBoy's Avatar
JimmyBoy
Default Coilovers
Got a couple of questions regarding the use of coilovers on a Series 2 RS Turbo.
I am interested in getting myself a set, but have heard in the past the rear of the S2 is not really well suited to the use of coilovers as it puts alot of stress on the rear which it was not designed for, and extra strengthening would be useful if I was to go ahead with some, what are peoples thoughts on this?
What ride hieght do people think is best for "normal" driving? I believe 25mm is meant to be best as any more can give understeer? anyone shed more light on this?
What make would people recommend going for? I was considering getting a set of Gaz coilovers, but was also aware of the AVO coilovers. Anyone got any recommendations?
Thanks in advance for any advice
Old Nov 30, 2005 | 01:25 PM
twinkle_2k86's Avatar
twinkle_2k86
correct me if im wrong, but i didn`t think you could fit coilovers on the rear of a S2 as the spring and shock are separat from each other.
my mate had coilovers on the front of his S1 and had lowered springs and shocks on the back, he had AVO`s on his.
Old Nov 30, 2005 | 03:10 PM
320 bhp's Avatar
320 bhp
IVE GOT GAZ COIL OVERS ON ALL 4 CORNERS AND THERE GREAT,DRIVES AND HANDLES A LOT BETTER THAN IT DID WITH KONIS ON
Old Nov 30, 2005 | 03:16 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
twinkle_2k86, the coilover replaces the spring and shock obviously, so if it come sin one unit then it will fit, to put it simple
The problem on the rear is the turrets are not wide enough, but can be modified with a big hammer or properly by fabricating wider ones
Old Nov 30, 2005 | 03:54 PM
addiction's Avatar
addiction
rear turrets should also be reinforced to take coil overs
Old Nov 30, 2005 | 04:34 PM
JimmyBoy's Avatar
JimmyBoy
Anyone know of a good place to buy coilovers ?
Old Dec 1, 2005 | 01:04 AM
NUTS RuS's Avatar
NUTS RuS
Click the sig - Bilstein direct fit with NO turret mods required
Not GAZ or AVO prices unfortunatly but you get what you pay for in this world.
Old Dec 1, 2005 | 05:17 AM
Red16's Avatar
Red16
Tony i want some of these
you say the front comes with spherical bearing top mounts, i already have a pair of these in the loft waiting to be fitted to my RS1600i, would you be able to supply the struts seperately and would they fit my RS16i top mounts? cheers
Old Dec 1, 2005 | 06:25 AM
NUTS RuS's Avatar
NUTS RuS
Of course we can supply without
Call Martin at MEF - or drop him a PM on here. What type of 16i top mounts have you got ?
Old Dec 1, 2005 | 07:01 AM
Red16's Avatar
Red16
i got these mounts, im not at home at the minute so got no part numbers etc just this pic
im not in a position to buy the coilovers just yet as im still busy prepping the cars shell, so i dont want to ring up til im ready to buy, but i like to get things sorted in my head so i know what i can and cant get hold of
Old Dec 1, 2005 | 02:32 PM
nigel b's Avatar
nigel b
ive had konis and they are ok
gaz coilovers are slightly better
im now using bilstein coilovers and they work well without a harsh ride
jessie_rs
62
Aug 6, 2019 09:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
S3an
13
Sep 13, 2015 10:01 AM
