ERST
front and rear arches are bolted on with little nuts u have to remove the inner wheel arch spats and u can feel em (they usually snap)side skirts are pop riveted on underneath the car if i remember correctly
Gota do it, going to the bodyshop !! n/s/f arch, both rear arches, delocked, opening up the front bumper and then the bonnet. LOADSA DOSH!
want me d reg looking mint tho
the sideskirts are held on by phillips screws into the sills,once you remove the screws the skirts pulls up off a rail on the sill.
the front arches are held on by 4 or 5 nuts and a screw through the sill.
back arches are held on by rivets which have to drilled out.
both the front and back arches are also held with a double side'd tape.
be prepared for something to break and the probable need to drill the screws holding the sideskirts on.
i did all this to mine when i had a bare metal re-spray last winter.
also dont be suprised when the cost of doing it spirals rapidly
Originally Posted by rs tommy
jus to get the sides off, do the arch bits have to come off first?
Mc5506
Oct 5, 2015 09:57 PM
