Help please is this a.....
Old Nov 28, 2005 | 12:11 PM
Default Help please is this a.....
Anti lag valve as it looks different to the Mountune one and a std ISCV Apparently Grp A
Old Nov 28, 2005 | 12:26 PM
...dont all rush in
Even if you dont know,call me a cock or something
Old Nov 28, 2005 | 12:28 PM
Disabled Account's Avatar
Disabled Account
COCK!
rsnissan's Avatar
rsnissan
cock
...ok chaps that was a joke
Old Nov 28, 2005 | 12:30 PM
Disabled Account
And theres me thinking this thread would go to 12 pages now Phil
Old Nov 28, 2005 | 12:31 PM
Disabled Account
BTW that actually looks like a standard ISCV to me
Old Nov 28, 2005 | 12:32 PM
Stealth Bomber's Avatar
Stealth Bomber
Cock Jockey!
Porkie's Avatar
Porkie
Doug, I forgot! Ford made a Puma 1.6.... so
Old Nov 28, 2005 | 12:33 PM
Spiky's Avatar
Spiky
defo different from std, as the rod doesn't normal stick out that far (i think)
...the mountune picture of a std one looks different????
Have i been conned on EBay for the first time?..LOL
Old Nov 28, 2005 | 12:36 PM
Disabled Account
OH yes, thanks Lee, I did some research and you are correct - the 1.6 did replace the 1.4 model.........to me it just seemed strange Ford offering the car in 1.6 & 1.7 engine versions
Old Nov 28, 2005 | 12:39 PM
The 1.7 was a totally different engine though wasnt it? ie a yahama engine?
Old Nov 28, 2005 | 12:42 PM
Disabled Account
Default Re: Help please is this a.....
Originally Posted by Bosch-Man
Maybe the only difference is the spring (i.e. spring rate) thats fitted
Old Nov 28, 2005 | 01:24 PM
anyone else?
Old Nov 28, 2005 | 01:29 PM
bud-weis's Avatar
bud-weis
Football Cwazy
have a look at this
not sure what the mods are to make it into an anti lag valve, but yours doesn't have the end piece with the O-ring
http://www.motorsport-developments.c...products_id=42
Old Nov 28, 2005 | 01:40 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Phil,
That is the nasty one that has been mentioned in other posts where if the screw comes loose it drops into the engine . I would not fit this to my car if I was you (for the above reason). It is not a Mountune item.
I could have had your standard ISCV modded for Ł60 and that would have been ultra reliable and flown enough air for mild ALS.
Old Nov 28, 2005 | 01:52 PM
Disabled Account
E-Bay strikes again....
TBH Phil with all the knolagable peeps on here (like Mike R etc) you should post/ask on PassionFord BEFORE bidding for these so called bargains........lesson learned I suppose
Old Nov 28, 2005 | 01:53 PM
It's Czech Mate's Avatar
It's Czech Mate
All the shortblock zetec-s/se were developed by yamaha 1.25 1.4 1.6 and 1.7
The 1.7 is different in so much as it has discrete vct on the ehxaust valves and a better intake manifold
Old Nov 28, 2005 | 01:55 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
The one i had, the mountune one, its totaly different in operation to the standard one, and looks nothing like that one either.
Its just one giant valve going up and down, wheras the standard one is a small piston that moves up and down in a casing.
Old Nov 28, 2005 | 03:35 PM
....as Tim Finch said in my other thread just use a suitable locktite and problem solved....Far more to worry about than the nut coming loose if correctly installed!
Old Nov 28, 2005 | 03:36 PM
...incidentally what is the nut and thread for...it looks like it is adjustable????
Old Nov 28, 2005 | 03:42 PM
Cam's Avatar
Cam
Not worth risking imo get a properly modded one and sell the eBay one.
Old Nov 28, 2005 | 04:00 PM
Yes but using locktite would mean you have just as much chance as a cam nut going loose and causing damage!....Its fine!...and to be extra sure i will check it every now and again!
Old Nov 28, 2005 | 04:01 PM
Cam's Avatar
Cam
Fair play
stundies
Ford Escort RS Cosworth
11
Jul 22, 2007 12:17 AM
james_birch
Feb 13, 2005 03:54 PM
