focus 18 zetec
hi everone justs joined,wifes not happy never been off the site since
shes giving me loads but hay ho
can anyone shed any light or have had the same problem the ignition key locks out when i try to start her (the car not the wife) your input will be much appreciated
[/img]
[/img]
can you give us a bit more info mate,un less im not reading it right
big chris can anyone shed any light or have had the same problem the ignition key locks out when i try to start she (the car not the wife) your input will be much appreciated
yes no probs when you put the key in and turn to start wont go any further than second click its like its already started and the barrier is there that stops you engaging the starter again its driving me nuts it would'nt be any good as a get away car
sounds like the ignition barrel *might* need replacing,something may have moved in side,not sure how or why though
try spraying a bit of wd40 in to the barrel see if it helps any
or you could try phoning a car locksmith to see what he advises
TPM961
Jan 15, 2018 10:50 AM
grishenko45
Sep 9, 2015 12:58 PM
