whats needed to hit the 200bhp mark on a s2 turbo?
Old Nov 23, 2005 | 10:18 PM
twinkle_2k86's Avatar
twinkle_2k86
Default whats needed to hit the 200bhp mark on a s2 turbo?
im wanting 200 bhp out of my turbo once running, but whats needed to get the magical 200bhp.
at the mo it got,
collins stage 1 chip
full stainless mongoose exhuast
k&n pannel filter in drill airbox
hybrid stage 2 t3 turbo
- 31
low comp bottom end
standard intercooler.
what would this produce and what boost would i need to get to 200BHP,
cheers
Old Nov 23, 2005 | 10:28 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Change the intercooler to a GRS item or something similar
Maybe a high lift cam, not sure on what to recommend
Decent set up and about 18psi should do it
Old Nov 23, 2005 | 11:23 PM
only mods i done is
GRS intercooler
alloy rad
chipped
14psi
-31 actuator T2 cam
magnex
K&N induction
mine car is 192BHP but was 197BHP b4 i put the GRS on it and my actutor is a bit fooked atm
Old Nov 24, 2005 | 09:58 AM
John Laverick's Avatar
John Laverick
Just fit an intercooler, run some more boost and it'll hit 200BHP no problem imo [as long as the engine is nice and healthy!!]
Old Nov 24, 2005 | 10:11 AM
twinkle_2k86
supurb, so not much to spend on the old girl to get her up there then.
the engine is not bad, its have a new piston as it had a crap one fitted, but pj motorsport are going to do me a fully matched one for me. and while the engines aprt im chaging a few parts just so there all new and i wont have to worry about them.
the engine is only on 61k so should be ok, and the turbos nearly new as well.
so new intercooler and trip to the rollers it is then, cheers peps
oh one other thing, im runnng a standard ford cam,and i hear these are very good, but would i benafit from have a vernier pully on it to get the best from the cam??
Old Nov 24, 2005 | 10:15 AM
T28 RST's Avatar
T28 RST
Ok then
Isnt it pointless fitting a vernier to a standard cam
Old Nov 24, 2005 | 11:22 AM
John Laverick
Its not pointless fitting a vernier to a standard cam as it will allow you to get the timing dialled in perfectly [although your not gonna see/feel any real gains imo]
The standard cam is very good and many tuners swear by them BUT.....they do have quite a high wear rate usually lasting only 60'000 miles ore so before the lobes wear. So you'll probably find your cam is already quite worn.
An alternative cam that is recommended by many is the Piper 285 [Not the T2]
Old Nov 24, 2005 | 04:27 PM
im actually going back to using a standard cam. the cvh loves to eat other cams
Old Nov 24, 2005 | 05:27 PM
Charlie Chalk
Unknown.
big_Rad
Sep 15, 2017 09:36 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
mpilk
Aug 12, 2015 09:40 PM
col93saphcos
Aug 7, 2015 03:21 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
