IB5 final drive - weak point?
Old Nov 15, 2005 | 11:51 AM
Rick's Avatar
Rick
Default IB5 final drive - weak point?
I have never - touch wood - had a problem with my gearbox, and it's still going strong. What is that tends to break on them? Is the final drive (ie 3.82:1) in the diff or box? Does this ever break?
Rick.
Old Nov 15, 2005 | 11:55 AM
AndyRST's Avatar
AndyRST
But dont you only have 200bhp rick? If so you dont need to worry yet
Oranoco's Avatar
Oranoco
The layshaft I beleive is the week point as it carrys load as well as being a bearing surface.
iirc
Old Nov 15, 2005 | 11:58 AM
Rick's Avatar
Rick
AndyRST
ever watched QI? Cos the alarm bells are ringing
Old Nov 15, 2005 | 12:16 PM
JesseT's Avatar
JesseT
Layshaft bearing is the most usual thing to break. That bearing however has been changed to a bigger one in teh IB5 gearbox. The old S2's BC gearbox still has the smaller one. The IB5 bearing can be transplanted to the BC gearbox with minimal machining required. Our local machinist does the conversion for around 45e.
TPM961
Jan 15, 2018 10:50 AM
Eigdoog
48
Sep 19, 2015 11:03 AM
xrmalin
Sep 13, 2015 06:52 PM
The Enigma
Sep 12, 2015 10:12 PM
Adam Graham
Sep 6, 2015 06:04 AM
