Smoking when cold?
Old Nov 14, 2005 | 08:11 AM
mantamark's Avatar
mantamark
Default Smoking when cold?
When i first start driving my s2, there seems to be some blue smoke, but after 2 mins, its gone, is this normal?
Want to get her in tip top cond, dont want anything to be wrong if poss.
cheers.
Old Nov 14, 2005 | 09:27 AM
RS_JAY's Avatar
RS_JAY
Valve stem seals?? Im sure when they go the oil leaks into the chamber. Hence the blue smoke on start up. Someone correct me if im wrong.
Old Nov 14, 2005 | 09:39 AM
MadMac's Avatar
MadMac
Can be a number of things.
Sometimes smoke is just water being evaporated out the exhaust and its more noticable on a cold day.
Could be worn piston rings or valve stems too, even an old turbo will leak oil when cold then as all these parts warm up they expand and seal properly and dont smoke anymore.
Old Nov 14, 2005 | 01:16 PM
antony215's Avatar
antony215
Escort Rs Turbo
More than likely the vavle stem seals get a set from ford or www.burtonpower.co.uk not the cheap one's for the motor factors
Old Nov 14, 2005 | 01:42 PM
Rick's Avatar
Rick
Valve stems seals, turbo, breather, or its running too rich
Old Nov 14, 2005 | 03:03 PM
mantamark's Avatar
mantamark
i was going to get the valve stem oil seals done soon anyways, i have checked all the breathers, hope it isnt the turbo, but i know it has been set up a little rich, better too rich than too lean
Old Nov 14, 2005 | 03:43 PM
addiction's Avatar
addiction
probably the valve stem oil seals,very common problem with the cvh
Old Nov 14, 2005 | 05:42 PM
Oranoco's Avatar
Oranoco
As above. Piece of piss to sort yourself. Just make sure you get the one piece top hat style ones and not the two piece ones. Budget on half an afternoon if you're doing it on your tod
Old Nov 14, 2005 | 06:33 PM
andre_k's Avatar
andre_k
one of the best things i have doen to my rst was the valve stem seals
Old Nov 14, 2005 | 07:07 PM
mantamark's Avatar
mantamark
Cool, so the ones from burton are one peice?
Is there a how to guide anywhere?
Done it about 4 years ago on my old xr2, but had a guide & cant remember now
Cheers for all the help.
Worth doing the tappets at the same time?
Old Nov 14, 2005 | 07:42 PM
Oranoco's Avatar
Oranoco
Just get them from Ford. Think they were under £15 iirc. Get a decent tool for about £10 and the rest is a doddle.
Take the spark plugs out as it makes it easier to turn the engine by hand and also stuff rag around the vlve you are working on. Dropping a collet down an oil way is a right pisser
Old Nov 14, 2005 | 07:44 PM
mantamark's Avatar
mantamark
will change the plugs & leads at the same time, whats decent for these engines?
cheers for the help
Old Nov 14, 2005 | 08:01 PM
Oranoco's Avatar
Oranoco
For leads the proper Ford jobbies are about as good as they get.
Plugs wise I tend to use Bosch C57's but I think the Fiesta has Ford PC08's (don't quote me on the Fiesta as I'm not sure )
Old Nov 14, 2005 | 08:45 PM
RS_JAY's Avatar
RS_JAY
For changing the seals. i used a compressor and a tool i have that goes into the end of the compressor hose, then in the the spark plug holes what puts pressure on to the valves, so they dont fall into the chambers. Easyier then taking the head off.
tools i needed.
compressor
Compressor valve
Valve stem tensioner thing to push the springs down.
Im sure some of the lads on here will tell you an easyier way...
Old Nov 14, 2005 | 08:58 PM
Oranoco's Avatar
Oranoco
Why on Earth would you take the head off
Old Nov 14, 2005 | 09:05 PM
antony215's Avatar
antony215
Escort Rs Turbo
you want one of these if your doin the valve stem seal's you dont have to take the head off
£10 plus the p+p from www.burtonpower.co.uk
Old Nov 14, 2005 | 09:08 PM
Oranoco's Avatar
Oranoco
That's the kiddy
Old Nov 14, 2005 | 09:11 PM
antony215's Avatar
antony215
Escort Rs Turbo
That's the kiddy
They were £5 when i got mine best £5 i ever spent save's all the hassle of taking the head off
Old Nov 14, 2005 | 09:13 PM
Oranoco's Avatar
Oranoco
Agreed their mate
Wouldn't be without mine in my toolbox
Old Nov 14, 2005 | 10:11 PM
mantamark's Avatar
mantamark
I shall have one in my toolbox soon
Old Nov 15, 2005 | 01:29 PM
antony215's Avatar
antony215
Escort Rs Turbo
Make sure you read the instruction's because you have to have the piston's to the top when taking the valve colliks out otherwise the valve will fall down into the chamber then that mean's head off to get the valve out
Old Nov 15, 2005 | 06:04 PM
RS_JAY's Avatar
RS_JAY
Im sure ive heard ppl in the past take the head off? Maybe they were doing some internal work aswell. Thats the tool though. Mine was fiver from motorworld or what ever its called. Agreed, VERY handy tool!
Old Nov 15, 2005 | 06:12 PM
antony215's Avatar
antony215
Escort Rs Turbo
if you dont have the above tool then you have got to take the head off to do the seal's because the other tool was a clamp type thing
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
