OMG I need cossie rear brake help urgently!! *SORTED*
Old Nov 13, 2005 | 11:08 AM
Rippers's Avatar
Rippers
Monte Geek
Default OMG I need cossie rear brake help urgently!! *SORTED*
I've never been so stuck with something on a car in my life! Really embarassed and totally fucked off!
This was suposed to be a half hour job that has turned into a complete nightmare
I'll admit I've fooked up but I need help getting out of this jam! Please help PF!
Basically I needed to fit longer wheel studs to the Esc Cos did the fronts very easy.
The rears.. I couldn't see how I would get the studs in and out because of the rear brake shield so I took the rear caliper off to see if I could get better clearance at the top... nightmare begins...
I couldn't get any better clearance and it turned out there was enough clearance at the bottom of the shield to do the job anyway.. cool so I thought put the caliper back on end of prob... oh so wrong
I couldn't get the caliper back on because of the clearance between the pads wouldn't fit on the disc. I couldn't push the caliper piston back in it was hard as a rock.. so I thought if I took the handbrake cable off it would release the pressure and the piston would go back in.. what a mission spent about 2 hours (no lie) trying to get this fooker off the hook managed to force it off and it didn't make any difference then fucking around with the handbrake hook I managed to push the caliper piston out further! and pull off the spring on the hook
Ok so then totally stuck I still couldn't get the piston back in so I thought if I undid the bleed nipple this may release pressure.. nope so then fucked off I took the whole caliper off and even with a vice and Francos 19 stone on top of it the pistons wouldn't go back in, Franco suggestion was that it was jammed so started turning the pistons back and forth to see if that freed it up... nope but then he realised the pistons could be screwed back in.. so with a clamp he spun the piston back into the caliper... I have no idea if this is what your suppose to do or whether this caliper is now fucked
Any way so the pads back on the disc and bolted up, after a shit load of effort I managed to get the handbrake spring back on but now I'm fucked if I can get the bloody handbrake cable back on the hook.. surely there is an easier way of getting this back on I unclipped it from the beam but it made no difference, have I got to unclip it from the hand brake inside the car or something?? Try as I might I cannot get this cable hooked back on
I'm really fucked off with myself and really need this sorted! plus any advise on waht we did with the calipers piston please
Old Nov 13, 2005 | 11:10 AM
peteh's Avatar
peteh
when i did it on my 4x4 saph i found a section of the shield that was further away from the disk so you could realise them from the hub then, then drop them out if you turned the hub round, i know that doesn't make sense
Old Nov 13, 2005 | 11:12 AM
Go under the car and look for the handbrake adjuster and slacken it right off
Old Nov 13, 2005 | 11:13 AM
Rippers's Avatar
Rippers
Monte Geek
Yeah thats what I've done the stud job is done.. I've just totally fucked my rear brakes up thou
Old Nov 13, 2005 | 11:14 AM
Rippers's Avatar
Rippers
Monte Geek
Where abouts is this? under the handbrake?
Old Nov 13, 2005 | 11:16 AM
Well on a saff its over to the passenger side in front of the rear wheel..a big plastic knob..LOL....i am assuming the Escos has the same cable set up!Should have.
I had the same scenario recently with the saff
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
yep, thje calipers are supposed to be twisted back.
use a pair of pliers on the handbrake lever on the caliper to pull it 'on', then try to get the loop end of the cable over it... simple once you've done it a few times, but i know how frustrating it can be if you've never done it before.
Old Nov 13, 2005 | 11:17 AM
peteh's Avatar
peteh
sorry, id better read the whole post next time
MD you need to slacken the cable first mate imo!!!
Old Nov 13, 2005 | 11:21 AM
Turbo Zetec
Engine Machinist
bosch-man... good idea to try that first
Old Nov 13, 2005 | 11:22 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
@ putting 19stone on the piston and getting frustrated THEN realising it screws in sorry but you gotta laugh or you'll cry!!
Old Nov 13, 2005 | 11:23 AM
Rippers's Avatar
Rippers
Monte Geek
Cheers guys phew! I've not fucked the piston by screwing it in!
Also another rear caliper question. When the handbrake spring came off I took the bolt that holds the spring loaded against the hook and the whole hook raised up by about a 1.5cm out of the caliper I hammered it back down and bolt the bolt back on.. is it normal for this to pop out? I guess the bolt usually holds this down.
I really hope the above makes sence (thats why I didn't mention it before)
Old Nov 13, 2005 | 11:24 AM
Ginge !'s Avatar
Ginge !
just finding my feet
are you sure you should be playing with brakes mate
first of all the rear brakes on a cossie need to be screw back in due to the ratchet system, that means that has been done correctly
now as fo the hand brake, take IMA's advice as thats spot on
now ou just need to rebleed the system and promise never to work on your cossie again without posting if you are unsure
Rippers's Avatar
Rippers
Monte Geek
Mate I've never been so fucked off in my life at a car.. I'm hoping I will get to laugh about this later today after its sorted (at work till 1:00)
Old Nov 13, 2005 | 11:25 AM
Rippers's Avatar
Rippers
Monte Geek
Its a promise
Ginge !'s Avatar
Ginge !
btw you can still buy the handbrake rear caliper section from fords if you need any of that part, i chucked one away the other day infact
Old Nov 13, 2005 | 11:38 AM
vroooom ptssssh
It Wasnt Me!
You'll look back when its fixed and piss yourself mate honest
Old Nov 13, 2005 | 11:50 AM
...BTW when you bleed the rear brakes make sure the car is on the ground and not jacked up.
Old Nov 13, 2005 | 11:54 AM
Ginge !'s Avatar
Ginge !
phil you try doing that on the floor with monte wheels
measure the wheel hubs height then jack up to that point
Old Nov 13, 2005 | 11:56 AM
Rippers's Avatar
Rippers
Monte Geek
Cheers for the advise lads! btw cab you mix brake fluid? I have some DOT5 at home?
Old Nov 13, 2005 | 11:59 AM
Ginge good point
Yes you can mix aslong as thats not DOT 5 silicone based!
Old Nov 13, 2005 | 12:03 PM
Ginge !'s Avatar
Ginge !
just redo the whole system with 5.1 , may aswell tbh as theres gonna be bubbles and save mixing fluid
1 litre from fords is about 4 quid and the finis is 1135521 i belive
Old Nov 13, 2005 | 12:11 PM
Gadget's Avatar
Gadget
Spanner monkey
Pen pushers and mechanical work just don't go together!!
paul, stick to selling houses and Franco, stick to putting the bins out
HTH!
Old Nov 13, 2005 | 05:24 PM
Damo V's Avatar
Damo V
as above the handbrake cabes are a cnt of a job... though tbh I cant remember how I did mine, when I fitted new calipers... Just to point out there IS a detailed and precise procedure to follow when bleeding the rear brakes... It is detailed in the workshop manual
Old Nov 13, 2005 | 05:28 PM
Damo it is if you dont know what you are doin like me before my mate said.."why not loosen the cable off you complete cock suckin homo c*unt"
Old Nov 13, 2005 | 06:20 PM
Damo V's Avatar
Damo V
No trust me Phil I lreleased the handbake
Old Nov 14, 2005 | 09:03 PM
Rippers's Avatar
Rippers
Monte Geek
All sorted many thanks Phil and MD Cos...
Old Nov 14, 2005 | 09:07 PM
Ginge !'s Avatar
Ginge !
HEY !!!! , what about me and damo too
Old Nov 14, 2005 | 09:15 PM
Rippers's Avatar
Rippers
Monte Geek
sorry b19bal and Damo aswell
On the plus side the handbrake feels great
Old Nov 14, 2005 | 09:16 PM
Ginge !'s Avatar
Ginge !
and damo !!!!, need to thank him as hes gonna be usefull considering you have the same car as him
Old Nov 14, 2005 | 09:19 PM
Rippers's Avatar
Rippers
Monte Geek
Edited
original
Apr 28, 2026 05:20 PM
Timmy74
Ford Mondeo Including ST
Aug 28, 2015 01:21 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
