3 hard drives
I ve built my own computer (1st time novice)
But have now run out of hard drive space (massive mp3 collection!)
and wanted to add a 3rd hard drive i have space in the case but was not sure on the wiring?
hows it done?
hows it done?
Right, as standard you have 2 IDE channels on your motherboard. This can run a maximum of 4 drives.
If you look at my CD Drives, you'll see the cable runs direct from the motherboard, to the DVD-RW (bottom drive) then into my DVD Drive (top drive)
top drive is master, 2nd drive is slave, and that's it basically
HTH
HTH
yes you can buy spiltters. I dare say you will be ok with a 500w power supply. I am running 3 hard drives drives, 2 DVD drives and 5 fans with the standard power supply that came with my case.
These are what I have in my machine
http://www.ebuyer.com/customer/produ...duct_uid=57662
And this is all ebuyer list for hard drive controllers
http://www.ebuyer.com/customer/produ...ice&show=stock
TPM961
Jan 15, 2018 10:50 AM
