water leak.....
Old Nov 1, 2005 | 07:15 PM
dave_y's Avatar
dave_y
Default water leak.....
can someone help me find the source of my problem. i noticed the water in the header tank was going down faster than it should do and then i noticed that there is an obvious leak coming from the block, it looks as though it originates from just under the exhaust manifold. near the yellow sticker in the picture below...
any help would be muchly appreciated!
Old Nov 1, 2005 | 07:18 PM
stevenebm's Avatar
stevenebm
post whore
doesnt look good mate if its coming from there
Old Nov 1, 2005 | 07:20 PM
dave_y's Avatar
dave_y
i know
Old Nov 1, 2005 | 08:20 PM
Manchester Mike's Avatar
Manchester Mike
Is it not leaking at the core plug??? Should be easy to sort if it is
Old Nov 1, 2005 | 08:23 PM
dave_y's Avatar
dave_y
thats the sort of answer i like. 'easy to sort'
cant be dealing with major problems right now, its due to go into the bodyshop (again) at the weekend.
will have a look.
Old Nov 1, 2005 | 08:48 PM
dave_y's Avatar
dave_y
ok your all gonna think im real stupid but....
i think the majority of the water in that pic originates from the slatted hole that Ford put in the bonnet.
note water marks running down the exhaust manifold and cambelt cover.
however there is definately a coolant leak somewhere as the header tank has gone down quite a bit.
Old Nov 1, 2005 | 10:07 PM
adamS2RST's Avatar
adamS2RST
Leaky core plug by the looks of things Easy enough to fix mate, you can get a whole core plug replacement kit for the cvh from Burtons for a few quid! Only hard thing is knocking the old one out the block, not too much trouble tho!
Old Nov 1, 2005 | 10:53 PM
dave_y's Avatar
dave_y
any reason what would cause this to leak or is it just general wear and tear.
eg: is there a bigger problem?
thanks for all your replies chaps!
Old Nov 1, 2005 | 11:40 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Who told you this?
knock the old one out by using a screwdriver and a hammer, place the screwy in the centre or at the edge on the inside of the core plug and give it a dunt, it will disfigure it and allow it to come out easy!
https://www.burtonpower.com/dets_pro...p=09027&PSet=1
Their the chaps your after.
then fitting all you need to do is chap them in gently, preferably with a rubber mallet or a piece of wood across the tops so they go in evenly and square!
MAKESURE IT IS THESE LEAKING FIRST!!
Also check around the water pump.
P.s. cant think of a reason why they would leak other than general wear and tear as you say, makesure your coolant mixture is correct as the only other reason they may leak or pop out is if your coolant freezes, it wil expand and look for the weakest point to come out.
Old Nov 2, 2005 | 06:33 AM
adamS2RST's Avatar
adamS2RST
Who told you this?
Old Nov 2, 2005 | 07:03 PM
dave_y's Avatar
dave_y
thanks for all your input people. turned out to be rain water in the end.
ran the car on the drive for 5 minutes and it was still bone dry. must be where i drove the car in the rain and it dripped off the engine overnight.
i thought the header tank looked low on coolant but then i realised that it rises once the car is running so thats why i thought it must have gone down a lot!
Old Nov 2, 2005 | 07:13 PM
vroooom ptssssh
It Wasnt Me!
i want reimbursted for my time
Old Nov 2, 2005 | 07:26 PM
dave_y's Avatar
dave_y
lol am sorry, am gonna treat myself to an stainless vent plate to prevent it happening again!
Old Nov 2, 2005 | 07:42 PM
adamS2RST's Avatar
adamS2RST
Old Nov 2, 2005 | 09:40 PM
vroooom ptssssh
It Wasnt Me!
Kidding on mate Adams gonna send me his car up for compensation
Old Nov 2, 2005 | 10:00 PM
adamS2RST's Avatar
adamS2RST
Keep dreaming u c*nt!
Old Nov 3, 2005 | 01:47 AM
vroooom ptssssh
It Wasnt Me!
shit i better call the transporter company and cancell
Old Nov 3, 2005 | 06:53 AM
adamS2RST's Avatar
adamS2RST
Old Nov 10, 2005 | 08:07 PM
Mr C's Avatar
Mr C
Just wondering what Coolant you guys recommend, anything better than anything else??
Old Nov 10, 2005 | 09:49 PM
vroooom ptssssh
It Wasnt Me!
Wouldnt of thought so mate, it all does the same job really, some will be dearer than others but i cant see much bennefit, might be wrong though!
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
