bosch group a fuel pump 0580254003
i use the .....023 pump
but this will be fine
not sure why you need it though, small turbo esc cossies wont break 320 bhp on std eeciv management, so a direct replacement fit pump will suffice
i'm sure i had the 003 on mine.
Do need a fitting kit,but wjhen mine was properly set up roughly 375,Karl said the fueling was well enough.
Do it once,get the best one you can.
JK12
33
Apr 26, 2021 12:09 PM
