Major help needed !
Old Oct 23, 2005 | 11:57 PM
SamERST's Avatar
SamERST
Default Major help needed !
Tonight on my way home the orange light with a picture of a car skiding kept flickering on and off really quickly as if there was a loose connection or something ??? Then later i had to do an emergency stop then emedently after theres this constant metal grinding noise like something was draging on the floor, so i got underneath but i couldnt see anything So i took it really easy home with this loud noise still constantly there then about half way home that orange light stayed on and its still on now ??!! Plus the car now wants to stall everytime i come to a stop
Has anyone come accross this before ? as i want to sort of know where to begin looking for the problem.
Sam
Old Oct 24, 2005 | 12:10 AM
bassboy's Avatar
bassboy
its the abs light...
Old Oct 24, 2005 | 12:11 AM
Bungle's Avatar
Bungle
Hiya not many on at this time so i thought i'd lend a hand so here goes; the light in question is your anti lock brakes light (ABS) and they have sensors on to tell you your brake pads are low which sounds to me like your problem mate. i'm 99.9% sure so don't go too far if anywhere and expect your brakes to save you cos chances are they won't, take a look or get them checked out ASAP. hope this helps you out, Good luck with it, Regards, Grant.
Old Oct 24, 2005 | 07:39 AM
GrimmeRS2K's Avatar
GrimmeRS2K
or there are sensors in the belt modulators, they are a thin strip of metal with wires going to them inserted into the belt covers, which sensors the grooves on the driveshaft, one of these could of fallen inside
Old Oct 24, 2005 | 10:51 AM
SamERST's Avatar
SamERST
Hi guys thanks for the replys, I did think it was something to do with the brakes at first but then with one of my previous cars when the pads were low it only made the noise when braking not a grinding noise all the time.
Ill have a look at the pads later, and i think it could be the belt modulators as the noise is constant.
Thanks again ill post later as i get on.
Sam
Old Oct 24, 2005 | 01:46 PM
Bungle's Avatar
Bungle
nice one grimme that's a new one on me so make that just 99% sure. let us know how it goes sam.
Old Oct 24, 2005 | 03:59 PM
addiction's Avatar
addiction
the sensors in the abs modulator covers are in contact with the abs belt,usually means the belt has snapped or the sensor is faulty when the light comes on
Old Oct 24, 2005 | 04:14 PM
Oranoco's Avatar
Oranoco
The ABS light has nothing to do with brake pad wear. It is solely there to tell you the ABS belt is either loose or broken. As the light is flickering it would indicate the belt is loose rather than broken.
Undo the modulator retaining bolts and retension the belt or the best option is to pop into your local friendly tuner and get the ABS system removed. The brakes will be transformed for the better
Old Oct 24, 2005 | 04:59 PM
Bungle's Avatar
Bungle
i'm saying nothing, i could be wrong if so fair enough i'll hold my hands up but that's the experience i've had, it happened to me when my pads were worn and as a result they came loose explaining both the abs light and the embarrassingly loud scraping noise but i'll wait for the verdict from sam for now.
yorkie92
27
Sep 22, 2017 05:56 PM
3i Jim
Nov 20, 2015 05:12 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
