Shells for line bored blocks
Are these available from ford, i have a 0.4mm line bored block which i want new shells for but not much point in rebuilding the engine if i can't get hold of them
Thanks in advance, again
How come you didnt get the caps skimmed first so that it was back to std size?
I bought the engine to strip down and rebuild, when i took the crank out i noticed that the main bearing shells said..
STD (crank side)
+0.40 (block side)
is there anyway i can get around having to pay for these from ford or should i just be prepared for them to spank me?
Thanks for the help guys
When you line bore a block you can either take it out bigger to get it round again, or you can skim the faces and then linebore it back at the original size.
Ive always used the method where they stay the same size and use the same bearings.
I see what you mean now mate thanks, yeah would be great if i could use origanal size bearings but the block had already been line bored before i got my hands on it.
So looks like over £200 just for new mains then
bloody crank is mint as well, doesn't need a regrind, its its just having a polish.
Wish the block hadn't been line bored
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
timsrs
22
Sep 24, 2015 08:14 PM
