Anybody fit a pedal box too there RS Turbo
Old Oct 16, 2005 | 03:31 PM
Johnny Knoxville's Avatar
Johnny Knoxville
Default Anybody fit a pedal box too there RS Turbo
As about.
I now working on my brake on the car and want them to be the best thay can. I'm going to rip out the ABS and fit braided hoses and 4 pots
Old Oct 18, 2005 | 01:15 AM
Johnny Knoxville
bttt
Old Oct 18, 2005 | 03:22 PM
NUTS RuS's Avatar
NUTS RuS
I have a home made bias box fitted on the Escort
When you say pedal box did you mean bias pedal box ?
Old Oct 18, 2005 | 03:49 PM
Dan's Avatar
Dan
Tony, that looks wicked, how do they work then?
Also, who did your cage, I take it that goes right through the bulkhead and joins with the rest of the cage?
Old Oct 18, 2005 | 04:00 PM
NUTS RuS's Avatar
NUTS RuS
Basically the brake pedal directly pushes the 2 pistons in the back of the cylinders. No silly cross over bars to flex and lose effort through etc. The harder I push the pedal the more fluid gets pumped around the circuits so the pads are clamped to the disc stronger.
All the cage was done by us mate and yes your correct
Some other brief pics here
https://passionford.com/forum/viewto...117875#2117875
Old Oct 18, 2005 | 04:09 PM
Johnny Knoxville
Thats what i meant Nuts the only problem is with the set up you have that would hit the back of my engine when your rover engine sits forward for more rooms
Old Oct 18, 2005 | 04:25 PM
gus's Avatar
gus
this is how fords done it all them years ago
i still need to get mine sorted (god im lazy)
brom might be able to help you out with this
Old Oct 18, 2005 | 05:32 PM
NUTS RuS's Avatar
NUTS RuS
Mine was made to fit.... yes,
but then anything can be made to fit anywhere without trying too hard
Old Oct 18, 2005 | 06:22 PM
Johnny Knoxville
I know how this setup works i just wanted to see how people have done it.
Just trying to sort out my RST for track days, the engine is the last thing on my list so i want to sort out all the brakes and handling
I've had a word with Brom and he's been very helpfull but there are a few things he has to keep a secret witch i understand.
Also working on a hydrualic clutch conversion right now as i was sick of snapping cables
Old Oct 19, 2005 | 08:41 AM
Scott R's Avatar
Scott R
If you are planning on going for a hydralic clutch why not fit a floor mounted pedal box, that way you will get the master cylinders up the back of the dash, only need to have room in engine bay for the resevoirs then
Old Oct 19, 2005 | 02:21 PM
Johnny Knoxville
Sorted it out now dont need one of them i've modified the standard box to work
Old Oct 19, 2005 | 05:34 PM
gus's Avatar
gus
pics
Old Oct 19, 2005 | 07:53 PM
Red16's Avatar
Red16
pics ? would like to see what youve done here please
Old Oct 19, 2005 | 08:57 PM
Johnny Knoxville
I've only manage to do the clutch only so far and will be working on the bias box for the brakes
I'll get pics up when its all done
Old Nov 3, 2005 | 05:58 PM
Johnny Knoxville
He is a pic of my mates modified std pedal box for a hydraulic clutch conversion and he is building mine for me to.
Andrew my mate will be selling his soon as he is fitting a Willwood pedal box
Old Nov 3, 2005 | 06:02 PM
gus's Avatar
gus
tony in a post before you and brom both said no to fitting a floor mounted set up
why was this? as it looks like the easiest way
neil18
Mar 14, 2016 01:08 PM
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
marky_g
Aug 15, 2015 10:43 AM
