things to check once an engine is run in?
Old Oct 16, 2005 | 11:23 AM
rapidcossie's Avatar
rapidcossie
Default things to check once an engine is run in?
obviously you put proper oil in it but what other things are worth checking?
cheers!
Old Oct 16, 2005 | 11:26 AM
Ginge !'s Avatar
Ginge !
just finding my feet
bank account and over draught
Old Oct 16, 2005 | 11:46 AM
essexrsturbo's Avatar
essexrsturbo
Old Oct 16, 2005 | 11:52 AM
rapidcossie
the bank account was fooked a long time ago! pmsl!
its rapidly coming up on the magic 1k and was just wondering ...
everything seems tight etc.
cant wait to finally give it some beans as i fooking hate driving around using zero boost getting overtaken by grannys!
what about re torque head bolts etc?
Old Oct 16, 2005 | 12:01 PM
Matt's Avatar
Matt
why run it in @ zero boost?
Old Oct 16, 2005 | 12:06 PM
rapidcossie
was told not to load the engine up too much
only use a couple of psi and not to go above 4k revs.
sounded like good advice to me...
Old Oct 16, 2005 | 01:11 PM
Cam's Avatar
Cam
I was told the same about running in the new GTR motor. 2psi and 4krpm max for 1st 600 miles then an oil change and check for leaks/loose fasteners. Next 1400 miles at 6psi and 5krpm.
kosienutter
31
Aug 22, 2015 09:55 AM
ekjim
Aug 17, 2015 08:57 PM
Zoggon
Aug 10, 2015 10:39 AM
knight19770
Aug 4, 2015 12:36 PM
ginger1979
Jul 31, 2015 09:56 PM
