ERST on koni's and 17's
Old Oct 11, 2005 | 10:46 PM
escortlad's Avatar
escortlad
Default ERST on koni's and 17's
Hi,im looking into buyin koni's and have been told i should only lower my rs turbo 25mm - 30mm and was woundering what you lot here think and also i would like to see some pictures of your cars lowered 25mm or 30mm on 17's.
Old Oct 11, 2005 | 11:32 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
very common setup now on RST's now mate....lowered 30mm shud be perfect with 17s
Old Oct 12, 2005 | 09:04 AM
bassboy's Avatar
bassboy
mine...7x17 oz crono evo's and 45mm drop
bassboy
Old Oct 12, 2005 | 09:32 AM
T28 RST's Avatar
T28 RST
Ok then
I have Konis and chassis dynamic 25mm lowered springs, the car sits really well with minimal rubbing
Old Oct 12, 2005 | 10:07 AM
adamS2RST's Avatar
adamS2RST
Mine...at the mo sitting 25mm on PI suspension so it's not great.... however it don't rub but I have modded the rear springs slightly
Old Oct 12, 2005 | 10:12 AM
KSA-Cossie's Avatar
KSA-Cossie
Any lower than -25mm and you tend to suffer from understeer.
Old Oct 12, 2005 | 08:55 PM
escortlad's Avatar
escortlad
thanks for all your replys,all your cars looked mint.i think im goin to go for some 30mm springs with top adjustables.
Old Oct 13, 2005 | 01:46 AM
Combi_Chris's Avatar
Combi_Chris
i have 17`s and lowered 30 mm, it NEVER rubs , and my subwoofer is 30 kg`s in weight , go ahead buddy you will be fine
Old Oct 15, 2005 | 12:41 AM
escortlad's Avatar
escortlad
ad4m rst was you in brighton at macdonalds about a month ago when the was a lot of people up there?
Old Oct 15, 2005 | 05:01 PM
Combi_Chris
here i thought id get some proppa piccys , 17`s with 40`s lowered 30mm
FRONT
REAR [ WITH DIRT ]
SIDE SHOT
Old Oct 16, 2005 | 09:46 AM
escortlad's Avatar
escortlad
i like ur combi mate ive got system 2 shocks on there at the mo which are not bad but would rather koni's,any had system 2 shocks too?what did you think of them?
Old Oct 16, 2005 | 10:21 AM
AJC's Avatar
AJC
mine lowered 40mm on koni adjustables
Old Oct 16, 2005 | 09:57 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
i got a set of heavy duty caravan springs in the rear of mine just cut them so same hight as 30 drop rears, can run my konis on soft with a boot and bk full and get 0 rubbing at the bk , standard 30s on the front
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
beller
Sep 21, 2015 04:13 AM
truffleshuffle
Sep 10, 2015 09:35 PM
Ellsa
Aug 9, 2015 07:03 PM
